2D Simulation using simpleFoam (Error)
Old   March 9, 2012, 08:42
Default 2D Simulation using simpleFoam (Error)
skyinventorbt's Avatar
Dr. B T KANNAN
skyinventorbt is on a distinguished road
I am trying to simulate a plane jet problem. Basically started from pitzDaily tutorial.
I have created mesh using blockMesh and the blockMeshDict file is as below...
convertToMeters 0.001;
vertices
(-1 0 0) //0
(0 0 0) //1
(0 0 0.1) //2
(-1 0 0.1) //3
(-1 0.5 0) //4
(0 0.5 0) //5
(0 0.5 0.1) //6
(-1 0.5 0.1) //7
(250 0 0) //8
(250 0 0.1) //9
(250 0.5 0) //10
(250 0.5 0.1) //11
(0 200 0) //12
(250 200 0) //13
(250 200 0.1) //14
(0 200 0.1) //15
blocks
hex (0 1 5 4 3 2 6 7) (10 20 1) simpleGrading (1 1 1)
hex (1 8 10 5 2 9 11 6) (500 20 1) simpleGrading (10 1 1)
hex (5 10 13 12 6 11 14 15) (500 400 1) simpleGrading (10 40 1)
edges
patches
patch inlet
(0 4 7 3)
patch outlet
(8 10 11 9)
(10 13 14 11)
wall nozzleup
(4 5 6 7)
wall domainleft
(5 12 15 6)
symmetryPlane sym
(0 1 2 3)
(1 8 9 2)
empty frontAndBack
(0 1 5 4)
(1 8 10 5)
(5 10 13 12)
(3 2 6 7)
(2 9 11 6)
(6 11 14 15)
mergePatchPairs
when i try to solve this using simpleFoam I get this following error.
$ simpleFoam
| \\ / O peration | Version: 1.7.1 |
| \\ / A nd | Web: www.OpenFOAM.com |
| \\/ M anipulation | |
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting RAS turbulence model kEpsilon
--> FOAM FATAL ERROR:
This mesh contains patches of type empty but is not 1D or 2D
by virtue of the fact that the number of faces of this
empty patch is not divisible by the number of cells.
From function emptyFvPatchField<Type>::updateCoeffs()
in file fields/fvPatchFields/constraint/empty/emptyFvPatchField.C at line 150.
FOAM exiting
"KINDLY SUGGEST ME TO SOLVE THIS ERROR"
skyinventorbt is offline   Reply With Quote
Old   March 9, 2012, 09:47
Martin
MartinB will become famous soon enough
you forgot one side of your domain in your patch definition. Therefor it becomes a "defaultFaces" patch with "empty" condition assigned.
You can see the missing side in paraFoam easily by importing the Mesh Parts one after another.
Good luck
Martin
MartinB is offline   Reply With Quote
Old   March 12, 2012, 00:32
Dr. B T KANNAN
Thank You Martin !!
Now the simulations are going on . . . .
Another doubt is whether OpenFOAM does real time simulation ?
Old   March 12, 2012, 03:30
GregorS's Avatar
Gregor Seljak
GregorS is on a distinguished road
If you use simpleFoam, the answer is no. Because every time step in simpleFoam is really just one iteration. So it doesn't matter whether you set
time step to one second or one milisecond.
But if you use other solvers, like pimpleFoam or pisoFoam, I think the answer is yes.
GregorS is offline   Reply With Quote
Old   March 13, 2012, 22:30
Default 2D plane jet simulation Error in simulation
Dr. B T KANNAN
I just submitted the 2d plane jet problem which i mentioned above in the first post. The velocity is 10 m/s. Kindly see the snapshot of velocity field.
The velocity field shows discontinuous patches which is unphysical !!
What is the procedure to get physically possible solution for this 2d plane jet problem ??
Old   March 15, 2012, 11:39
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Can you post a picture of the mesh in that region please? Also, how many iterations have you run?
lovecraft22 is offline   Reply With Quote
Old   March 15, 2012, 23:34
Dr. B T KANNAN
About 10,000 iterations !!
CGNS Compiling Diego Main CFD Forum 17 December 21, 2014 01:40
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 13:43
