Strange Solution
Old   March 28, 2012, 06:18
Default Strange simpleFoam solution after increasing sHM refinement levels
vigges is on a distinguished road
Hi folks,
my problem is as follows:
I have a 'simple' 2D problem consisting of a diffuser (see pictures) and a wall on the right side of the diffuser (not displayed on pictures). The task is to simulate jet impingement and Nusselt number on the wall. The dump's top and bottom are defined as outlets. The inlet height is 0.01 and the entire domain is 0.4625 x 0.65 x 0.002.
As you can see, the diffuser flow is going in the wrong direction (see flow_arrows.jpg), but only when I apply the refinement levels displayed in 'flow_mesh.jpg'.
As soon as I reduce the center region's refinement by one to level 1, I get a diffuser flow in the right direction.
Additional Info:
solver: simpleFoam
turbulence model: k-omega-SST
boundary conditions:
inlet
U [mapped, uniform (15 0 0), cell, true, (15 0 0)]
p [zeroGradient]
k [fixedValue, uniform 0.856]
omega [fixedValue, uniform 660]
nut [fixedValue, uniform 0.0013]
outlets
U [zeroGradient]
p [fixedValue, uniform 0]
k [zeroGradient]
omega [zeroGradient]
nut [calculated, uniform 0]
walls
U [fixedValue, uniform (0 0 0)]
p [zeroGradient]
k [fixedValue, uniform 0]
omega [omegaWallFunction, uniform 50]
nut [nutkWallFunction, uniform 0]
Any ideas how to fix this problem?
Thanks a lot in advance
I'm more than happy to provide more info if needed
Last edited by vigges; March 29, 2012 at 04:26. Reason: providing more information
vigges is offline   Reply With Quote
interFoam solution tolerances mgdenno OpenFOAM 4 September 13, 2011 12:58
upwind schema strange results; Solution of Versteeg example differs from OpenFOAM sol idrama OpenFOAM 12 May 10, 2011 05:38
Transient, initial variables from a previous solution nakor FloEFD, FloWorks & FloTHERM 0 April 22, 2011 04:34
Unsteady solution Christophe FLUENT 0 August 11, 2006 11:13
Discussion about Mesh independant solution Seb Main CFD Forum 13 May 22, 2001 13:37
