-   -   ico only running with a crazy small time step (http://www.cfd-online.com/Forums/openfoam-solving/98995-ico-only-running-crazy-small-time-step.html)
tellico March 23, 2012 07:41
I am running a model of flow in a pretty basic channel (2m wide x 4 m in length x 4m tall) and I can only keep the Courant number in check if I run it with a time step of 1e-16.
My block mesh uses a (40 40 40) grid, and going any finer on this means that the computation times takes ages.
With my current time step a simple simulation would take several weeks to run. Does anybody have any further tricks on how to keep the Courant number in check with a reasonable time step?
It seems to be a trade-off between a super fine mesh and a super small time step, both of which mean really long computation times.
kmooney March 23, 2012 09:29
Is the max velocity in the domain realistic? You might be having a velocity blow up which is driving down the Co and deltaT down.
tellico March 23, 2012 11:57
thanks for the reply, my max velocity is reasonable, but I'm now wondering if I haven't messed something up in my U file:
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
Wall8 //inlet
type fixedValue;
value uniform ( -0.4 0.4 0.1 );
Wall6
type fixedValue;
value uniform ( 0 0 0 );
Wall7
type fixedValue;
Wall9
type fixedValue;
Wall10
type fixedValue;
Wall12
type fixedValue;
Wall17 //outlet
type zeroGradient;
Wall20
type fixedValue;
Wall21
type fixedValue;
Wall22
type fixedValue;
Wall27
type fixedValue;
Wall28
type fixedValue;
lovecraft22 March 23, 2012 12:28
I'm having the same problem…
http://www.cfd-online.com/Forums/ope...-cylinder.html
kmooney March 23, 2012 12:35
You may be facing a problem with numerical stability. What kind of fvSchemes are you using? A more diffusive/stable convection discretization scheme might help.
If you're looking for a steady-state solution you might be able to get away with running upwind for a little while and switching over to more accurate schemes later on in the run.
tellico March 23, 2012 14:55
Thanks for the suggestion. I will look for examples of the fvScheme that you suggest. I'm currently using the following fvScheme:
ddtSchemes
default Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss linear;
laplacianSchemes
default none;
laplacian(nu,U) Gauss linear corrected;
laplacian((1|A(U)),p) Gauss linear corrected;
interpolationSchemes
default linear;
interpolate(HbyA) linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
