Home > Forums > OpenFOAM Running, Solving & CFD
engineFoam with layers - pressure problems when adding layers
Like Tree1Likes
Old   April 12, 2013, 12:12
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
You can plot the logSummary file using gnuPlot.
Vito31388 likes this.
mturcios777 is offline   Reply With Quote
Old   May 14, 2013, 10:13
sqing
Sunxing is on a distinguished road
Originally Posted by conceptone View Post
Hi Marco,
Thanks for suggestion. Actually I have tried reactingFoam to check the chemical and combustion part. While I always get messages like below after a period of time(0.0007s):
[0] --> FOAM FATAL ERROR:
[0] Maximum number of iterations exceeded
[0]
[0] From function specieThermo<Thermo>::T(scalar f, scalar T0, scalar (specieThermo<Thermo>::*F)(const scalar) const, scalar (specieThermo<Thermo>::*dFdT)(const scalar) const) const
[0] in file /usr/apps1/openfoam-2.1.1/OpenFOAM-2.1.1/src/thermophysicalModels/specie/lnInclude/specieThermoI.H at line 69.
[0]
FOAM parallel run aborting
[0]
[1]
so I use tutorial case's mechanism and therm.dat...I don't know what's the problem here(even tutorial case can't run..)
I guess I can try to change the function T in speciethermoI.H like in openfoam-ext-1.6 to avoid computing ending..
if (iter++ > maxIter_)
// Improvements: graceful exit with recovery. HJ, 11/Oct/2010
InfoIn
"specieThermo<thermo>::T(scalar f, scalar T0, "
"scalar (specieThermo<thermo>::*F)(const scalar) const, "
"scalar (specieThermo<thermo>::*dFdT)(const scalar) const"
") const"
) << "Maximum number of iterations exceeded. Rescue by HJ"
<< endl;
// Use value where dFdT is calculated using T0. HJ, 11/Oct/2010
Tnew = f/(this->*dFdT)(T0);
return Tnew;
} while (mag(Tnew - Test) > Ttol);
Hi conceptone,
I have met the same problem as you posted, have you solved it? please let me know.
regards
Sunxing
Sunxing is offline   Reply With Quote
Old   October 17, 2013, 02:52
Apoorv Talekar
apoorv121 is on a distinguished road
try reducing deltaT
apoorv121 is offline   Reply With Quote
Thread Tools
Trackbacks are On
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
Problems with extrapolation of pressure in BC Sergio Main CFD Forum 0 July 17, 2008 09:05
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 02:15
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
Has the pressure correction method problems? X. Ye Main CFD Forum 17 September 1, 1999 16:14
