decomposeParDict errors when deleted
Old   April 3, 2012, 14:27
Default decomposeParDict errors when deleted
Mihai Pruna
mihaipruna is on a distinguished road
I'm not running my case in parallel, why does my meshing crash when I erased the file?
Mihai Pruna's Bio
mihaipruna is offline   Reply With Quote
Old   April 3, 2012, 14:44
lore
lovecraft22 is on a distinguished road
Send a message via Skype™ to lovecraft22
Don't know why but sHM checks that file anyway so you need to leave that where it is.
lovecraft22 is offline   Reply With Quote
Old   April 4, 2012, 04:48
Rider is on a distinguished road
Can you copy your error message here ?
Rider is offline   Reply With Quote
Old   April 4, 2012, 05:01
lore
--> FOAM FATAL IO ERROR:
cannot open file
file: /home/ubuntu/Desktop/condivisa/8_cilindro/system/decomposeParDict at line 0.
    From function regIOobject::readStream()
    in file db/regIOobject/regIOobjectRead.C at line 87.
FOAM exiting
This is mine, that is what you get when you do not have any decomposeParDict within you system folder.
Old   April 4, 2012, 07:45
Bernhard
Bernhard is on a distinguished road
Which utility are you trying to run here?
Bernhard is offline   Reply With Quote
Old   April 4, 2012, 07:57
lore
sappyHexMesh
Old   April 4, 2012, 09:08
Mihai Pruna
could this in any way be related to my other post where I stated that you cannot have more than two SHM instances running at the same time?
Mihai Pruna's Bio
Old   April 5, 2012, 11:54
Alberto Passalacqua
This is just because snappyHexMesh meshes on multiple processors/cores.
Alberto Passalacqua
Old   April 5, 2012, 13:07
Mihai Pruna
I see...does that apply to solvers as well?
Mihai Pruna's Bio
Old   April 5, 2012, 14:31
Alberto Passalacqua
No. Solvers and other utilities in general do not require a decomposeParDict.
Alberto Passalacqua
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
