Home > Forums > OpenFOAM Running, Solving & CFD
/multiphase/LTSInterFoam/wigleyHull
Old   April 5, 2012, 22:18
Default /multiphase/LTSInterFoam/wigleyHull
hs
parkh32 is on a distinguished road
Hi all
Is there anyone familiar with these Warnings and Errors ?
$ snappyHexMesh
Morph iteration 0
Calculating patchDisplacement as distance to nearest surface point ...
Wanted displacement : average:0.0268186 min:6.09635e-06 max:0.0622069
Calculated surface displacement in = 0.14 s
--> FOAM Warning : Displacement (-0.000832685 0.0136869 -0.00323482) at mesh point 44104 coord (-11.0566 3.70836 -2.29274) points through the surrounding patch faces
Smoothing displacement ...
Iteration 0
Iteration 10
Iteration 20
Displacement smoothed in = 6.12 s
Undo iteration 0
Checking faces in error :
non-orthogonality > 65 degrees : 0
faces with face pyramid volume < 1e-13 : 0
faces with face-decomposition tet quality < 1e-30 : 0
faces with concavity > 80 degrees : 0
faces with skewness > 4 (internal) or 20 (boundary) : 0
faces with interpolation weights (0..1) < 0.05 : 0
faces with volume ratio of neighbour cells < 0.01 : 0
faces with face twist < 0.05 : 0
faces on cells with determinant < 0.001 : 0
Snapped mesh : cells:469687 faces:1458423 points:521507
Cells per refinement level:
0 7051
1 9326
2 387495
3 65815
Writing mesh to time 2
Wrote mesh in = 38.21 s.
Mesh snapped in = 86.3 s.
--> FOAM Warning :
From function layerParameters::layerParameters(..)
in file autoHexMesh/autoHexMeshDriver/layerParameters/layerParameters.C at line 379
Reading "/home/administrator/OpenFOAM/administrator-2.1.0/run/tutorials/multiphase/LTSInterFoam/vor70/system/snappyHexMeshDict::addLayersControls::layers" from line 240 to line 240
Layer specification for hull does not match any patch.
Valid patches are
5
inlet
outlet
atmosphere
sides
hull_bodyCreatedbyGmsh
$ paraFoam
--> FOAM Warning :
From function polyMesh::readUpdateState polyMesh::readUpdate()
in file meshes/polyMesh/polyMeshIO.C at line 204
Number of patches has changed. This may have unexpected consequences. Proceed with care.
--> FOAM FATAL IO ERROR:
size 14400 is not equal to the given value of 469687
file: /home/administrator/OpenFOAM/administrator-2.1.0/run/tutorials/multiphase/LTSInterFoam/vor70/100/nut from line 18 to line 14443.
From function Field<Type>::Field(const word& keyword, const dictionary&, const label)
in file /home/opencfd/OpenFOAM/OpenFOAM-2.1.0/src/OpenFOAM/lnInclude/Field.C at line 236.
FOAM exiting
thanks
HS//
parkh32 is offline   Reply With Quote
Old   November 12, 2012, 09:20
Jakub Pola
stainboy is on a distinguished road
Iteration 0
Iteration 10
Iteration 20
I'm very interested in this warning as well. What I've noticed when I've got this message during meshing process I'm obtaining mesh with strange holes. This problem is raised here
Is your mesh ok when you are obtaining this error?
--> FOAM Warning :
Valid patches are
5
inlet
outlet
atmosphere
sides
For that I believe you have used wrong patch name in the addLayers step. Just change the name to one mentioned in the list. it should be propably like this:
layers
         hull_bodyCreatedbyGmsh   // a_surface_name
            nSurfaceLayers 3;
The last error shows usually when you are reading steps generated by snappyHexMesh program. Every step often contain different number of cells due to meshing process therefore it can cause problems as you have here.
Best regards.
Jakub
stainboy is offline   Reply With Quote
Thread Tools
Trackbacks are On
