Home > Forums > OpenFOAM Running, Solving & CFD
Output files in time folders
Old   April 9, 2012, 05:15
Default Output files in time folders
Gilles De Neyer
gdeneyer is on a distinguished road
I'm having trouble using rhopimplefoam. There are 20 files in each time folder
- ddt0(p)
- ddt0(phi)
- ddt0(psi,p)
- ddt0(rho,h)
- ddt0(rho,U)
- ddt0(rho)
- ddt0(U)
- divU
- p
- p_0
- phi
- phi_0
- rho
- rho_0
- T
- U
- U_0
I am just interested in T,U,divU and p but I don't know how to ask the program not to save the other data's. There is no object in the source code for these quantities where I could put "NO_WRITE" like it's possible to do with p,U,T,div.
Sounds a minor problem but considering the size of my domain and the number of simulation that I'm doing, it's really a problem because I'm approaching the limit of my hard drive.
Thank you
gdeneyer is offline   Reply With Quote
Old   December 20, 2012, 16:48
hz283 is on a distinguished road
Hi Gilles,
Do you know how to ask the code stop outputing these *_0 files? I had the same problem now. I really appreciate it if you can give me some suggestions.
Thanks.
h
hz283 is offline   Reply With Quote
Old   December 21, 2012, 08:15
Gilles De Neyer
hello,
I didn't do it. These files come from the use of the backward scheme and it's quite interesting to let them in the case you wish to rerun from a certain time.
If you really want to drop them, you have to look in the source code for backward scheme ;-)
Regards,
Gilles
Old   December 22, 2012, 07:52
Lieven
Lieven will become famous soon enough
Hi Gilles,
Here is what you could do.
1. Set the regular output writing to a large interval (e.g. write over 1000 steps) so that you have a full backup of your simulation from time to time which makes it possible to restart if something would go wrong. Set purgeWrite to 1 or 2 so that only the last 1/2 folders are kept.
2. Use the writeRegisteredObject funtion to select the fields you want to write more regularly, in your case U, T, divU and p. Have a look at
http://openfoamwiki.net/index.php/Ti...gisteredObject
to see how to use this function.
The _0 files are indeed created by the time integration scheme. These will not be printed with the writeRegisteredObject function.
Kind regards,
L
Lieven is offline   Reply With Quote
Thread Tools
Trackbacks are On
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
separate .vtk files + OpenFOAM fields: synchronous time tomislav_maric OpenFOAM Post-Processing 4 November 21, 2011 10:34
critical error during installation of openfoam Fabio88 OpenFOAM Installation 21 June 2, 2010 03:01
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
