-   -   Using codestream in controlDict (http://www.cfd-online.com/Forums/openfoam-solving/99760-using-codestream-controldict.html)
pad April 11, 2012 03:59
Hi all,
I am having some trouble using #codestream in controlDict file.
Basically, what I want is outlined below:
transientRunTime 0.816326530612;
application transientSimpleDyMFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime #codeStream
code
scalar startFrom = readScalar(dict.lookup("startFrom"));
scalar runTime = readScalar(dict.lookup("transientRunTime"));
os << startFrom+runTime;
However, when I run the simulation I get the following error:
--> FOAM FATAL IO ERROR:
wrong token type - expected Scalar, found on line 22 the word 'startTime'
file: /storage/42938/Projects/Poseidon_2/E.35000W.50Hz.8P/EIMP.35.50.01.EVOL.35.50.01/Q100/system/controlDict::startFrom at line 22.
From function operator>>(Istream&, Scalar&)
in file lnInclude/Scalar.C at line 91.
FOAM exiting
Does anyone know how to get the value of 'startTime' assigned to 'startFrom' instead of the name 'startTime'
BR,
Per
