internal flow BCs: pressure driven versus velocity driven |
September 7, 2012, 14:18 |
#21 |
anonymous
Since you are using simpleFoam just add the following:
type totalPressure; gamma 1.0; p0 uniform 0; value uniform 0; You should be O.K now. |
March 6, 2014, 10:00 |
BC Total Pressure
#22 | |
Rep Power: 12 |
Dear OpenFoamers,
I would like to set up my study case: a water flow through a channel by simpleFoam. I want to set boundary conditions as total pressure: (1 bar at inlet and 0 bar at outlet). Now I have: ================================================== ==== p ================================================== ==== inlet type fixedValue uniform 100 ? for simpleFoam pressure = pressure/mass density, right? outlet type fixedValue uniform 0 ================================================== ==== U ================================================== ==== inlet type pressureInletVelocity uniform (0 0 0) outlet type zeroGradient It does not work when I ran simpleFoam! It stops after several iterations. I really don't understand what happened. Do you known why, rather why not? I am looking to hear from you all... Regards, T Quote:
March 6, 2014, 10:06 |
#23 |
Rep Power: 12 |
Thank MBA for your answer.
That's for p, right? And for both inlet and outlet? Preciously, I change in constant/transportProperties nu = 1e-6 to simulate water. It's OK? May you give me more details... That's would be useful. |
Maintaining Static Pressure at Fluid Flow Inlet | cdevalve | FLUENT | 3 | January 14, 2012 00:11 |
Channel flow: Inlet pressure AND uniform velocity? | frmap1 | Main CFD Forum | 0 | April 15, 2010 10:32 |
Pressure driven laminar flow simpleFoam pressure higher at the outlet than inlet | gabriel | OpenFOAM Running, Solving & CFD | 16 | September 30, 2009 18:20 |
Urgent: How to model a stationary sphere in a pressure driven flow using Ansys CFX? | farhan | OpenFOAM Running, Solving & CFD | 1 | April 14, 2009 14:34 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
