September 26, 2014, 08:20 |
Problem with vortex shedding frequency
Saravana Kumar Lakshmanan
Rep Power: 13 |
Hi friends,
I am currently trying to simulate flow past a circular cylinder for my thesis in OpenFOAM. I am having problem in getting the correct strouhal number. Drag coefficient is comparatively good. The following are the BC’s and details about mesh Dia=0.034 m; velocity=20 m/s; Re=45,000 ; Solver- PISOFOAM; RANS Model-kOmegaSST P-freestreamPressure at inlet & outlet, zeroGradient on cylinder (wall), Symmetry on Top & Bottom U-freeStreamVelocity at inlet & outlet, fixedValue (0) on wall, Symmetry on Top & Bottom k-fixedValue at inlet (based on k=3/2(UI)^2),zerogradient at outlet, FixedValue (0) on wall and kqrwallfunction, Symmetry on Top & Bottom omega-fixedvalue at inlet & outlet (based on omega=k^3/2/kcmul) basically took from one journal paper.For wall omega wall function and value =60nu/betaXdely^2. Symmetry for Top & Bottom nut-fixedvalue(0) at inlet, zerogradient at outlet,nutuspaladingwallfunction on wall, symmetry on Top and bottom. Mesh details: Y+=1, Four meshes are tested 50K,65K,80K,and 95K with max aspect ratio less than 22. The domain size is sufficiently long was used. fvSchmes: Time- Euler, gradschmes-Gauss linear, Divergence-Gauss limitedlinear,Laplacian-Gauss linear corrected Interpolation-linear, Sngrad-corrected Fvsolution: PCG with DIC as preconditioner for pressure with tolerance of 1e-06, reltol=0 For other terms PBiCG with DILU ,tolerance 1e-08 Ncorrectors=2,northogonalcorrectors=3 Please help me to solve this problem friends, Hope I described all important details |
September 26, 2014, 16:56 |
#2 | |
What about the time step size, did you try to use a smaller time step?
September 27, 2014, 09:24 |
Rep Power: 13 |
Hi taxalian
Thanks for your interest. Intially I used 5e-06 which gave max courant number 0.6-0.8. After your post today, I simulated with the time step of 1e-06 such that the max courant number less than 0.2. I simulated more than 140 non dimensional time units to avoid transient effects and started to monitor the values of Cl and Cd.Still I am getting reasonable drag value but strouhal number is high.I calculated this through calculating the time interval between peaks of the Cl plot as well as FFT of the Cl values.Manual calculated value is 0.25 and FFT value is 0.2464.The actual value for Re 45000 is 0.20.I also attached my case.Please have a look. https://drive.google.com/file/d/0B8S...it?usp=sharing |
November 20, 2014, 16:48 |
chubb87
Rep Power: 14 |
Did you solve your problem?
I would recommend using pimpleFoam instead of pisoFoam, to make sure convergence is achieved with a convergence criterion. I made the experience that with pisoFoam no relaxation should be used, but it seems you do not use relaxation. Isn't Y+=1 rather low, since you are using wallfunctions? |
November 23, 2016, 08:45 |
subhankar
Rep Power: 9 |
Hi all,
I am solving a similar problem but with reynolds number =100. I got strouhal number same but am unable to get correct Cd(drag co-efficient). drag co-efficient(Cd) calculated from the forceCoeff.dat through numerical integration doesn't match with that calculated from the formula Cd=F(drag force)/(0.5*density*diameter*Umax^2) and neither of them confirm with the actual result. Can anyone explain why? Since i am using 2-d simulations so in place of area in the Cd formula i used the diameter of the cylinder over which my flow is taking place. regards Subhankar |
cylinder, incompressible, komegasst, openfoam, shedding |
Which Foam for vortex shedding problem | Madeleine P. Vincent | OpenFOAM | 7 | November 20, 2018 06:31 |
fluent gets wrong airfoil vortex shedding frequency | eaglexyb | FLUENT | 0 | July 19, 2012 10:39 |
how can I determine the vortex shedding time step | Zhe Liu | CFX | 3 | July 30, 2008 17:16 |
Vortex shedding? | rbel038 | CFX | 4 | April 27, 2008 19:57 |
basic vortex shedding | john | Main CFD Forum | 4 | November 6, 2000 13:23 |
