CyclicAMI: Match Tolerance
Old   October 17, 2017, 17:40
Question CyclicAMI: Match Tolerance
Anders Utnes
Alasir is on a distinguished road
Hi
Im wondering how the Matchtolerance value used in the cyclicAMI BC is generally used.
Is it the tolerance relative to the size of the mesh? Or would a mesh in micrometer need orders of magnitude lower tolerance than a mesh in millimeters?
What are typical values?
What are the common sideeffects of putting the value to high or to low?
Any answers to any of these questions would be appreciated.
Alasir is offline   Reply With Quote
Old   May 13, 2019, 09:42
JuanMi
keitaro7_14 is on a distinguished road
I'm not 100% sure, but matchTolerance makes sense in a cyclic path, when the two faces have to match.
In cyclicAMI and cyclicACMI patches, it is included to match the cyclic template, but its value is not relevant.
It is my opinion, I'm not sure. Citing the documentation:
cyclic: enables two patches to be treated as if they are physically connected; used for repeated geometries; one cyclic patch is linked to another through a neighbourPatch keyword in the boundary file; each pair of connecting faces must have similar area to within a tolerance given by the matchTolerance keyword in the boundary file.
cyclicAMI: like cyclic, but for 2 patches whose faces are non matching; used for sliding interface in rotating geometry cases.
keitaro7_14 is offline   Reply With Quote
cyclicami;, matchtolerance
Time step continuity error lpz_michele OpenFOAM Running, Solving & CFD 0 October 12, 2015 06:05
Boundary Layer strange result fernexda OpenFOAM Running, Solving & CFD 14 January 15, 2015 07:21
STL import is not working zordiack enGrid 9 July 1, 2014 14:49
createPatch Segmentation Fault (CORE DUMPED) sam.ho OpenFOAM Pre-Processing 2 April 21, 2014 02:01
gmsh2ToFoam sarajags_89 OpenFOAM 0 November 24, 2009 22:50
