May 7, 2012, 16:09 |
interFoam behavior due to gh*grad(rho)
Jon Elvar Wallevik
Rep Power: 19 |
Dear foamers
Today I did something interesting with OF21x, and I think you should know about it (at least you who are using interFoam a lot). I took the original damBreak case and slided the solution area downward into negative y-direction (basically adding -4 in blockMeshDict in the y direction). I also changed setFieldDict so the case is physically the same as the original one. Both cases are in damBreakTest.gz (tar xzf damBreakTest.gz) Note that the density for phase 1 is extremely high in both cases, but similar is obtained with normal density values (but the difference is less clear then). I am often using high density liquids thus this is relevant for me. The point is that there is a difference between the two cases, and I belevie it is due to the gh*grad(rho) term (remember the "-gh*grad(rho)" term in the governing equation). For the original case, then gh<0 at the interface, while for the new case then gh>0. Now remember that the coordinate system is the same (i.e. y - axis points in the same direction for both the original and the new case). This means that for the original case the "-gh*grad(rho)" points in the same direction as "grad(rho)", meaning downwards. However, for the new case, "-gh*grad(rho)" points in opposite direction (i.e. upward), and thus the difference between the two cases. I think that the reason that the liquid (alpha1) is not going "up" for the new case, is other terms like the grad(eta) and surface tension (and perhaps other effects) are forcing it down. Strictly speaking this is not a code error (in my opinion), it is just how the gh*grad(rho) behaves, and you (interFoam user) should be aware of this. The point is, make sure that the origin of the coordinate system is at the lowest point in your system (at least this is what I do). Hope this is of help If you find other reason for the above difference, and if I am wrong in my conclusions, please post |
May 8, 2012, 03:01 |
Bernhard
Rep Power: 21 |
In this bug-report, Henry Weller explains this issue:
http://www.openfoam.org/mantisbt/view.php?id=356 |
May 8, 2012, 07:56 |
Jon Elvar Wallevik
Rep Power: 19 |
Thanks for the info Bernhard,
appreciate this J |
gh grad(rho) interfoam |
InterFoam stops after deltaT goes to 1e14 | francesco_b | OpenFOAM Running, Solving & CFD | 9 | July 25, 2020 06:36 |
Segmentation fault in interFoam run through openMPI | voingiappone | OpenFOAM | 16 | November 2, 2011 06:49 |
Slow interFoam compared with other CFD tools? | Ralph M | OpenFOAM Programming & Development | 1 | November 17, 2010 06:46 |
Temporal discretisation in interFoam | sebonator | OpenFOAM | 2 | August 21, 2009 07:39 |
Open Channel Flow using InterFoam type solver | sxhdhi | OpenFOAM Running, Solving & CFD | 3 | May 5, 2009 21:58 |
