Continue to run parallel
Dear foamers,
I run a case in parallel from 0s to 2000s. The job has finished. But I want to continue to run the case in parallel from 2000s to 4000s. How can I achieve that? |
Just change your controlDict file accordingly setting 2000 as startTime and 4000 as endTime.
blockMesh
setFields funkySetFields -time 0 decomposePar mpirun --hostfile $PBS_NODEFILE -np $np myFoamd -parallel Is it mean that I only need to run the last command "mpirun --hostfile $PBS_NODEFILE -np $np myFoamd -parallel" after I change the controlDict? Or can I use mapFields utility? |
I have run the reconstructPar command for the first 2000s. How can I reconstructPar from 2000s to 4000s?
You just need the solver command and at the end you should run reconstructPar again.
Many thanks for your ideas. It can work now.
