-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   cellSet - Divide Patch Wall in Pipe for implementation different BCs (http://www.cfd-online.com/Forums/openfoam/101729-cellset-divide-patch-wall-pipe-implementation-different-bcs.html)
franzi_ May 12, 2012 11:20
Hey,
I am using the forum since quite a long time now and always found really helpful posts, but to this topic I couldn't find what I was looking for.
I want to simulate the flow through a pipe with a constant wall tempreture on the outer wall. But in fact only part of the wall has a constant wall temperatur. On the pipe the first 40mm are adiabatic, than 60mm konst temp., again 40mm adabaitc and so on. (16 times)
- I hope I explained it understandable.
I tried to use createPatch und cellSetDict ( // Cells with centre within cylinder: cylinderToCell)to form that shape but it didn't work.
For the mesh I use Salome, but in fact it is overcharged with that mesh.
Does anyone have a hint what else I could try for this problem? Is there any other utility I still havn't found?
I really hope that somebody has a good idea.
Thanks a lot in advance
cheers, Franzi
PS: I am using OF 1.7.
nimasam May 13, 2012 07:18
ur answer is "groovyBC", you dont need to divide your patch you can apply your non uniform boundary condition with groovyBC
you can download it from here: "http://openfoamwiki.net/index.php/Contrib_groovyBC "
franzi_ May 13, 2012 08:54
Thanks a lot for the fast answer!!!
I already usw groovyBC for the BC Temperature on the wall like this:
aussen
type groovyBC;
variables "h=109.0;Tinf=494.0;rho=777.0;cp=2200.0;k=kappaEff *cp*rho;";
valueExpression "Tinf";
fractionExpression "1.0/(1.0+k/(mag(delta())*h))";
But I don't see any way to put in a condition. I want that half of the tube has the groovyBC condition as defined above und is other half zeroGradient for an adiabatic wall. Can I set something like -condition "pos().z>0.4 && pos().z<0.6" for the wall in groovyBC?
What about swak4Foam? I saw it in the forum and wonder if I can use that to make zeroGradient for different positions on the wall. But that only sets initial values, right ? no BCs that stays constant while simulating?
Oh, I am really confused at the moment...
Thanks in advance for helping!
Cheers Franzi
nimasam May 13, 2012 10:04
somethings like this:
valueExpression "pos().z > L ? 0 : T";
gradientExpression "pos().z > L ? q : 0";
