-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   how to plot V,p,F... in OpenFoam (http://www.cfd-online.com/Forums/openfoam/101791-how-plot-v-p-f-openfoam.html)
Teemo May 14, 2012 09:56
Hi everyone,
I am a new user of OpenFOAM and even linux system, I just download OpenFOAM 2.1.0 and Paraview from its official website and start to learn it.
I began with the tutorials inside the package and run some simulations. My question is, take Dambreak case as example, in Paraview I could only see how the situation looks like, is there any way to plot the velocity at a fixed point against time? and what's more important, where can i find the forces vs time on the dam?
Many thanks,
T
gschaider May 14, 2012 18:34
Originally Posted by Teemo (Post 360976)
Hi everyone,
Many thanks,
T
I'll give you just the buzzwords because there are enough discussions about this on the forum:
Velocity at point: look for the "probes" functionObject here on the forum
Forces: there is a "forces"-functionObject. I'm not sure how well it plays with interFoam.
Teemo May 15, 2012 04:45
Hello Gschaider,
I have tried to add force function in ControlDict file but it did not work since it was said that
error:keyword nu is undefined in dictionary
I did some search in this forum and it seems that there's some other guy have the same problem.
Do you have any idea about how to solve it?
Regards,
T
gschaider May 15, 2012 06:21
Originally Posted by Teemo (Post 361122)
Hello Gschaider,
Regards,
T
I'm afraid forces only works for non-multiphase-solvers (it tries treating interFoam as an incompressible solver and fails). Either someone programmed a interFoces-function object (I'm not aware of that but look around. It is not a totally excentric application) or you'll have to do it yourself. One possibility would be using the patchExpression-functionObject of swak4Foam which allows evaluating arbitrary expressions (as long as the fields exist) on patches. I describe that on slide 77 of http://www.openfoamworkshop.org/6th_...der_slides.pdf
