rhocentralFoam error while modelling hypersonic flow |
June 19, 2012, 11:33 |
Nathan Donaldson
Rep Power: 14 |
Hello all,
I'm a newcomer to OpenFOAM and am trying to model a hypersonic calibration model using rhoCentralFoam. After completing the Wedge15Ma5 and motorBike tutorials, I successfully created a mesh of my geometry using snappyHexMesh. The problem I'm having is that whenever I run the case and post-process it, the results (velocity, temperature and pressure) are all completely uniform. checkMesh returns no errors, and I've used a very small time step (0.001). Also, the mean and maximum Courant numbers remain constant between iterations, and the residuals prefixed with 'rho' are perpetually 0. The freestream boundary conditions I've tried to code are: Mach number = 17.8 Pressure = 29.5 Pa Temperature = 287K I've pasted in the Ma, p, U, T and blockMeshDict files below. Are there any errors that are immediately obvious? I'm sure it'll be something basic that I'm missing. Many thanks, Nathan Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object Ma; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 17.8; boundaryField { frontAndBack { type symmetryPlane; } outlet { type calculated; value uniform 17.8; } inlet { type calculated; value uniform 17.8; } lowerAndUpperWall { type symmetryPlane; } "HB2.*" { type calculated; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 29.5; boundaryField { frontAndBack { type symmetryPlane; } inlet { type zeroGradient; value uniform 29.5; } outlet { type zeroGradient; value uniform 29.5; } lowerAndUpperWall { type symmetryPlane; } "HB2.*" { type zeroGradient; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 1 0 0 0]; internalField uniform 287; boundaryField { frontAndBack { type symmetryPlane; } inlet { type fixedValue; value uniform 287; } outlet { type inletOutlet; inletValue uniform 287; value uniform 287; } lowerAndUpperWall { type symmetryPlane; } "HB2.*" { type zeroGradient; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (17.8 0 0); boundaryField { frontAndBack { type symmetryPlane; } inlet { type fixedValue; value uniform (17.8 0 0); } outlet { type inletOutlet; inletValue uniform (17.8 0 0); value uniform (17.8 0 0); } lowerAndUpperWall { type symmetryPlane; } "HB2.*" { type zeroGradient; } defaultFaces { type empty; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 1; vertices ( (-100 -50 -50) (-100 50 -50) (-100 50 50) (-100 -50 50) (400 -50 -50) (400 50 -50) (400 50 50) (400 -50 50) ); blocks ( hex (0 1 2 3 4 5 6 7) (10 10 50) simpleGrading (1 1 1) ); edges ( ); boundary ( frontAndBack { type symmetryPlane; faces ( (2 3 7 6) (0 1 5 4) ); } inlet { type patch; faces ( (0 3 2 1) ); } outlet { type patch; faces ( (4 5 6 7) ); } lowerAndUpperWall { type symmetryPlane; faces ( (0 4 7 3) (1 2 6 5) ); } ); // ************************************************************************* // |
hypersonic, openfoam 2.0.1, residuals, rhocentralfoam |
Solver for hypersonic flow in OpenFoam | Santos-Dumont | OpenFOAM Running, Solving & CFD | 19 | October 21, 2012 01:42 |
modelling slug flow with pressure inlet | Azman | FLUENT | 0 | May 29, 2006 06:45 |
modelling laminar and turbulent flow in the same | Ol | FLUENT | 2 | November 25, 2005 02:52 |
Modelling flow around a ship's hull using vof | Manoj Kumar | FLUENT | 0 | February 26, 2005 16:22 |
modelling flow in microchannel | Wang | FLUENT | 6 | October 10, 2000 09:28 |
