-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   problem about adding another equation of state (http://www.cfd-online.com/Forums/openfoam/101814-problem-about-adding-another-equation-state.html)
yhaomin2007 May 14, 2012 21:02
Hi, all foamers:
I want to imply another equation of state, so I copied the prefect gas file, and renamed it.
The compilation of the specie.so is successful, then I recompiled the solver. But when I run the solver it says:
Unknown basicPsiThermo type hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<RedlichKwong>>>>>
Valid basicPsiThermo types are:
11
ePsiThermo<pureMixture<constTransport<specieThermo <eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<eConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
ePsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
hPsiThermo<pureMixture<constTransport<specieThermo <hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<hConstThermo<perfectGas>>>>>
hPsiThermo<pureMixture<sutherlandTransport<specieT hermo<janafThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<constTransport<specieTherm o<hConstThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<sutherlandTransport<specie Thermo<hConstThermo<perfectGas>>>>>
hsPsiThermo<pureMixture<sutherlandTransport<specie Thermo<janafThermo<perfectGas>>>>>
From function basicPsiThermo::New(const fvMesh&)
in file psiThermo/basicPsiThermo/basicPsiThermoNew.C at line 60.
it seems that I have to put the new equation of state to somewhere.
Could somebody help me with this??
thank you in advance.:p
olivierG May 15, 2012 04:17
hello,
You should take a look at this thread:
http://www.cfd-online.com/Forums/ope...roperties.html
regards,
olivier
yhaomin2007 May 15, 2012 11:37
thank you very much~
yhaomin2007 May 15, 2012 13:47
hi, olivier:
I have seen the threads that you quoted. but I did not find the clear solution in it.
Do you have any ideas?
thank you
olivierG May 16, 2012 04:36
hello,
In this post http://www.cfd-online.com/Forums/ope...tml#post263539 you will find a step by step method.
Due to the multi layer structure in the thermoType, you need do modify more than one file. I don't know an easy "Howto" for that.
regards,
olivier
