-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   error while running in parallel using openmpi on local mc 6 processors (http://www.cfd-online.com/Forums/openfoam/102016-error-while-running-parallel-using-openmpi-local-mc-6-processors.html)
suryawanshi_nitin May 20, 2012 05:02
when i m running my case for parallel processing with following
mpirun -np 6 pisoFoam -parallel > log &
getting following error...
neptune@ubuntu:~/tutorials/incompressible/icoFoam/cavity$ mpirun -np 6 pisoFoam -parallel > log &
[1] 12387
neptune@ubuntu:~/tutorials/incompressible/icoFoam/cavity$ --------------------------------------------------------------------------
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]
[0]
[0] --> FOAM FATAL ERROR:
[0] number of processor directories = 2 is not equal to the number of processors = 6
[0]
FOAM parallel run exiting
[0]
mpirun has exited due to process rank 0 with PID 12388 on
node ubuntu exiting improperly. There are two reasons this could occur:
1. this process did not call "init" before exiting, but others in
the job did. This can cause a job to hang indefinitely while it waits
for all processes to call "init". By rule, if one process calls "init",
then ALL processes must call "init" prior to termination.
2. this process called "init", but exited without calling "finalize".
By rule, all processes that call "init" MUST call "finalize" prior to
exiting or it will be considered an "abnormal termination"
This may have caused other processes in the application to be
terminated by signals sent by mpirun (as reported here).
therefore after this i did parallel test
as mentioned in on of Brunos link
  1. Run mpirun with a test for launching mpi'less applications. For example, run each one of these at a time: Code:
    mpirun -np 2 bash -c "ls -l" mpirun -np 2 bash -c "export"
    The first one will show you the contents of the folder each remotely launched bash shell. The second one will show you the environment variables for each remote shell.
    If neither one of these work, then your MPI installation isn't working.
  2. Build the test application designed for these kinds of tests: Code:
    cd $WM_PROJECT_DIR wmake applications/test/parallel
    Now go to your case that has the decomposePar already done.
    Then run the following scenarios:
Till 2 step everything working ok but when i say parallelTest gives following error
neptune@ubuntu:~/tutorials/incompressible/icoFoam/cavity$ parallelTest
parallelTest: command not found
Thanks in advance... please help me on this....
adhiraj May 20, 2012 08:28
Why does it complain that you have 2 processor directories and are trying to run with 6 processors?
wyldckat May 20, 2012 10:45
Greetings to both!
@suryawanshi_nitin: Adhiraj is right, the decomposition apparently didn't go as you expected. Check your "system/decomposeParDict".
As for parallelTest, as of 2.0.0 it has been renamed to Test-parallel.
Best regards,
Bruno
suryawanshi_nitin May 20, 2012 13:37
Thnaks for your valuable replies
yes you are right, in my actual case i m working with 6 processors but it was giving issue, so i thought of checking with simple case. Below is the error msg of actual case. i have allready solved this case in of201 debian pack, till 1.7 sec by decomposing domain for 6 processors, And now i m using same data to solve further in of210 source pack installation. but while running it for further time after 1.7 sec but getting following error...
(And test-Parallel is working now)
neptune@ubuntu:~/nitin/s$ mpirun -np 6 pisoFoam -parallel > log &
[1] 2865
neptune@ubuntu:~/nitin/s$ [5]
[5]
[5] --> FOAM FATAL IO ERROR:
[5] essential value entry not provided
[5]
[5] file: /home/neptune/nitin/s/processor5/1.77/phi::boundaryField::symmetryBottom from line 59453 to line 59453.
[5]
[5] From function fvsPatchField<Type>::fvsPatchField
const fvPatch& p,
const DimensionedField<Type, surfaceMesh>& iF,
const dictionary& dict
[5]
[5] in file lnInclude/fvsPatchField.C at line 110.
[5]
[5]
MPI_ABORT was invoked on rank 5 in communicator MPI_COMM_WORLD
with errorcode 1.
mpirun has exited due to process rank 5 with PID 2871 on
kindly waiting for your replies. Thanks in advance.
Nitin
SirWombat May 21, 2012 08:31
[5]
What OpenFOAM is trying to tell you: Your "symmetryBottom" has a missing value in your boundary setup. Be sure to provide all needed variables!
suryawanshi_nitin May 21, 2012 14:13
sir thanks for your reply
its working well now, but i started the case from start time i.e. 0.0 sec in controldict file, a complete new simulation. From this what i understood is if we are having solution data of of debian pack of201 and if we want to run that case further in of210 source pack installation, then it of210 unable to understand/handle old data from old version especially in parallel case. this is what my interpretation.... thanks sir for your valuable time. if anyone is having clear view about this then they are most wellcome.
This is the way to learn fast with more clarity.....
regards
Nitin Suryawanshi.
