adding div(phi)
Old   May 31, 2012, 08:11
Default adding div(phi)
Nabil MEAH
bluemind is on a distinguished road
Hello everybody,
I'm currently working on the implementation of the some equations within the twoLiquidMixingFoam solver and I am facing some trouble when I try to add (in bold) an extra term in this transport equation :
fvScalarMatrix fracVolLVEqn
fvm::ddt(fracVolLV)
+ fvm::div(phi, fracVolLV)
- fvm::laplacian
Dab + alphatab*turbulence->nut(), fracVolLV,
"laplacian(Dab,fracVolLV)"
== fvm::div(phi, fracVolTot)
fracVolLVEqn.solve();
(fracVolLV =alpha1 (volumetric fraction of liquid) + alpha2 (volumetric fraction of vapor)
fracVolTot=alpha1 + alpha2+ alpha3 (volumetric fraction of air) ) equal to 1
When I compile, I don't have any errors however when I run the program I have the following error message :
--> FOAM FATAL ERROR:
incompatible fields for operation
[fracVolLV] == [fracVolTot]
Does anyone know how can I solve the problem ?
Thank you for the help,
bluemind is offline   Reply With Quote
Old   May 31, 2012, 08:22
akidess's Avatar
Anton Kidess
akidess will become famous soon enough
Try using fvc::div.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
akidess is offline   Reply With Quote
Old   May 31, 2012, 08:48
Nabil MEAH
Thank you for the answer, I have already tried to use fvc :: div (), and the program works (even if the calculation diverge at some point). But I'm confused about using an explicit resolution for this term whereas the other terms are resolved implicitly.
Old   May 31, 2012, 08:54
akidess's Avatar
Anton Kidess
You can only have one solution variable per equation. If you use fvm, the solver will see fracVolLV and fracVolTot as solution variables which cannot work.
Old   May 31, 2012, 08:58
Nabil MEAH
Thank you for the explanation I understand better now
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 09:48
Adding a new viscosity model ICL OpenFOAM Running, Solving & CFD 20 April 10, 2017 22:44
car Cd drops after adding inlet and outlet? wh88 FLUENT 0 October 19, 2011 13:23
Help with chtMultiRegionFoam jbvw96 OpenFOAM Running, Solving & CFD 2 December 26, 2010 17:16
Problem setting with chtmultiregionFoam Antonin OpenFOAM Running, Solving & CFD 3 July 20, 2009 06:52
