May 29, 2012, 07:30 |
Pressure is fluctuating
Sargentini
Rep Power: 13 |
Dear
I'm trying to simulate a laminar flow using Herschel Bulkley and "non-Newtonian solver." I adopted nu0 = 1E6, tau0 = 1, k = 0.01 and n = 1 to verify the result gives the analytical value of a Bingham material. The problem is that pressure is fluctuating too much, although the velocity gain a suitable profile. Someone please have an idea what might be happening and how to fix this problem. grateful Sargentini |
May 29, 2012, 07:34 |
Bernhard
Rep Power: 21 |
Maybe you can give some more relevant information, such as discretization and convergence criteria used? Also, which solver are you using?
May 29, 2012, 08:08 |
Sargentini
Rep Power: 13 |
I'm using nonNewtonianIcoFoam.
Follow the settings that have adopted: fvSolution: p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 4; nNonOrthogonalCorrectors 2; -------------------------------------------------------- fvSchemes { default Euler; } gradSchemes { default Gauss linear; grad(p) leastSquares; } divSchemes { default none; div(phi,U) Gauss upwind; } laplacianSchemes { default none; laplacian(nu,U) Gauss linear corrected; laplacian((1|A(U)),p) Gauss linear corrected; } interpolationSchemes { default linear; interpolate(U) linear; } snGradSchemes { default corrected; } fluxRequired { default no; p ; } ------------------------------------------------------------- p // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 2 -2 0 0 0 0]; internalField uniform 1; boundaryField { inlet { type zeroGradient; } outlet { type fixedValue; value uniform 1; } fixedWalls { type zeroGradient; } frontAndBack { type empty; } U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { inlet { type fixedValue; value uniform (0.1 0 0); } outlet { type zeroGradient; } fixedWalls { type fixedValue; value uniform (0 0 0); } frontAndBack { type empty; } --------------------------------------- Grateful for the support |
May 29, 2012, 11:52 |
Pressure is fluctuating ,Complementing
Sargentini
Rep Power: 13 |
Complementing:
HerschelBulkley.C ); return ( min ( }nu0_, (tau0_ + k_*rtone*pow(tone*sr(), n_)) /(max(sr(), dimensionedScalar ("VSMALL", dimless/dimTime,VSMALL ))) ) ); |
June 2, 2012, 08:44 |
mauricio
Rep Power: 17 |
Hi!
maybe you could upload a residual plot so we can take a look at your "fluctuation" your running a transient case (1st order euler scheme), plus you have 2 non ortoghonal correctors.. it means the pressure will iterate twice more than velocities..hence you'll c an oscillation which isnt an oscillation..but corrections from the solver. plus it's a transient case.. and you're suppose to have an oscillation like response... now how much it will oscillates it depends on the case.. might have said the obvious but setting things in OF sts makes you forget the basics hope it helps
Best Regards /calim "Elune will grant us the strength" |
June 2, 2012, 15:45 |
Sargentini
Rep Power: 13 |
Hi!
Thank you for your assistance. In fact, as I am a student in both subjects these issues are not so obvious to me. In this case, I was wondering what the formula written in the file HerschelBulkley.H, which considers nu0 would be more appropriate to the situation with the initial flow tau0 Yield stress, but it is only indicated. How can I use it? The file can be changed? This file is only available for reading. |
June 2, 2012, 20:25 |
mauricio
Rep Power: 17 |
Hi
im not on my desktop right now so i cant search through the files and be more specific.. but i guess you're using them nonNewtonianIcoFoam solver... try to examine the tutorial for this solver and change the viscosity model accordingly i might be of more assistnce once i get to my pc.. ps: c eh br?
Display Modes | |
Fluctuating Pressure Fields (LES-pisoFoam) | fluentfreak | OpenFOAM Running, Solving & CFD | 40 | November 21, 2019 07:09 |
Pulsatile pressure inlet with pressure outlet | a.lynchy | FLUENT | 3 | March 23, 2012 13:45 |
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
UDF to define or adjust pressure??? | engahmed | FLUENT | 0 | July 6, 2010 17:19 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
