-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   what kind of boundary condition should I use (http://www.cfd-online.com/Forums/openfoam/102947-what-kind-boundary-condition-should-i-use.html)
zakir hussain June 6, 2012 22:51
1 Attachment(s)
Dear all
I am simulating an MHD problem .liquid metal flows in a rectangular duct with external magnetic field.Now I run into trouble with the boundary conditions.I attached my details step here:
Can you give me some suggestion about the boundary condition of phi(BC)?
Thank you!
zakir
zakir hussain June 10, 2012 08:08
Does anyone can give me some suggestions?I am really in trouble with it.
Thank you!
zakir
wyldckat June 10, 2012 13:44
Greetings Zakir,
OK, you mention the kind of problem you want to solve, but you haven't mentioned yet which solver you are trying to use!
Best regards,
Bruno
zakir hussain June 11, 2012 01:16
Thanks for your attention.
I use a solver I wrote myself.It contains the knowdge about finite area method and finite volume method.First I need solve the 3D electric potential equation all
the fluid field with initial boundary condition.And then I have to solve a 2D electric potential equation (just like the file I have attached) on the boudary of fluid field. Then I need to use the solution of the 2D electric potential equation as the new boundary condition of solving 3D electric potential equation in the fluid field at the next time step.
I wrote my solver just as the attached file.
Have I expressed my point clearly?
Thank you for your advice.
zakir
gschaider June 11, 2012 04:31
the fluid field with initial boundary condition.And then I have solve a 2D electric potential equation (just like the file I have attached) on the boudary of fluid field. Then I need to use the solution of the 2D electric potential equation as the new boundary condition of solving 3D electric potential equation in the fluid field at the next time step.
zakir
Please don't include the main point of your question in a Bitmap. It is not possible to search that using the search function of the MessageBoard and the answers are therefor useless for everyone who might have the same question.
What you want is a FAM to FVM-coupling right. Something like
volSurfaceMapping mapper(famField.mesh());
mapper.mapToVolume(famField,  fvmField.boundaryField());
in your code copies the internal field of the famField to the appropriate patches of the fvmField (make sure the patches are of appropriate type ... fixedValue for instance)
PS: please don't send around duplicates of your question via EMail
zakir hussain June 11, 2012 10:48
yes, I have used the code you mentioned.But I don't know why it didn't calculate the 2D electric potential equation during a time step.The iteration number of solving 2D electric potential equation is zero.I doubt that I have applied the wrong initial boundary condition of electric potential (3D).Does the initial boundary conditions play that much important role during solving?
what kind of boundary condition should I use for electric potential (3D)?
regards!
zakir
zakir hussain June 12, 2012 05:03
1 Attachment(s)
Does the initial boundary condition in 0 dictionary paly a role in every time step ? For example when solving the 3D electric potential equation ,does the inputing file of 3D electric potential in 0 dictionary have influence on the solving in every time step?
regards!
zakir
GER_PL September 7, 2012 08:33
Hi zakir hussein and others,
which version of OF are you using? I was out of touch from OF for a few years, and it seems the the FAM is not part of OF-2.1! Any suggestions?
It looks like you are using FAM, so I thought you could help...
Thx,
Peter
zakir hussain September 7, 2012 09:17
Hi Peter
As I know,The FAM only exists at OF-1.6.ext.I still have many problem about that.We can discuss together.
regards!
zakir
