-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   Error with pimpleDyMFoam (http://www.cfd-online.com/Forums/openfoam/103104-error-pimpledymfoam.html)
samiam1000 June 11, 2012 05:52
Dear All,
when I try to run the pimpleDyMFoam I get this error:
lab@lab-laptop:~/Documenti/cases_OF/OF_case20_mesh_generation/0Deg$ pimpleDyMFoam
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.1.0                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
Build  : 2.1.0-0bc225064152
Exec  : pimpleDyMFoam
Date  : Jun 11 2012
Time  : 11:49:48
Host  : "lab-laptop"
PID    : 4105
Case  : /home/lab/Documenti/cases_OF/OF_case20_mesh_generation/0Deg
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Create time
Create mesh for time = 0
Selecting dynamicFvMesh dynamicMotionSolverFvMesh
Selecting motion solver: displacementSBRStress
Selecting motion diffusion: exponential
Selecting motion diffusion: inverseFaceDistance
Reading field p
Reading field U
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'boundaryField' on line 23 and ending at line 83"
file: /home/lab/Documenti/cases_OF/OF_case20_mesh_generation/0Deg/0/U at line 83.
    From function primitiveEntry::readEntry(const dictionary&, Istream&)
    in file lnInclude/IOerror.C at line 132.
FOAM exiting
The error is in the U file. Here it is:
FoamFile
    version    2.0;
    format      ascii;
    class      volVectorField;
    location    "0";
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 0 0);
boundaryField
    wall-volume_internal
        type            fixedValue;i
        value                uniform (0 0 0);
    symmetry_1-volume_external
        type            symmetryPlane;
    symmetry_1-volume_internal
        type            symmetryPlane;
    symmetry_2-volume_external
        type            symmetryPlane;
    symmetry_2-volume_internal
        type            symmetryPlane;
    wall_ext
        type            fixedValue;
    honeycomb
        type            fixedValue;
        value                uniform (-1 0 0);
    intake
        type            zeroGradient;
    bottom
        type            fixedValue;
    up
        type            fixedValue;
    wall_up_int
        type            fixedValue;
    door
        type            fixedValue;
Any idea?
Thanks a lot,
Samuele
eysteinn June 11, 2012 06:13
Originally Posted by samiam1000 (Post 365786)
Dear All,
Date  : Jun 11 2012
Time  : 11:49:48
Host  : "lab-laptop"
PID    : 4105
nProcs : 1
Create time
Reading field p
Reading field U
FOAM exiting
FoamFile
    version    2.0;
    format      ascii;
    location    "0";
    object      U;
boundaryField
        type            fixedValue;i
        type            symmetryPlane;
        type            symmetryPlane;
        type            symmetryPlane;
        type            symmetryPlane;
    wall_ext
        type            fixedValue;
    honeycomb
        type            fixedValue;
    intake
        type            zeroGradient;
    bottom
        type            fixedValue;
    up
        type            fixedValue;
    wall_up_int
        type            fixedValue;
    door
        type            fixedValue;
Any idea?
Thanks a lot,
Samuele
Hi Samuele.
Have you tried removing the trailing i in line 26?
/Eysteinn
samiam1000 June 11, 2012 06:21
Ooooops,
sorry!
Thanks a lot! That's ok, now!
Sam
