-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   turbulence with chtMultiRegionFoam (http://www.cfd-online.com/Forums/openfoam/103153-turbulence-chtmultiregionfoam.html)
dhruv June 12, 2012 10:20
1 Attachment(s)
Hello All,
I have running a case, which involves using turbulence model with chtMultiRegionSimpleFoam solver. The run is always giving me a floating point exception. I am using kOmegaSST model for turbulence, and BC are wall functions at the walls. I tried to change the BC near the wall to fixedGradient or zeroGradient, but when I run the solver, it automatically updates my boundary file for k and omega to run time selectable wall functions, and creates alphat and mut file.
The error is given as follows.
Create time
Create fluid mesh for region fluid for time = 0
Create solid mesh for region solid for time = 0
*** Reading fluid mesh thermophysical properties for region fluid
    Adding to thermoFluid
Selecting thermodynamics package hRhoThermo<pureMixture<constTransport<specieThermo<hConstThermo<perfectGas>>>>>
    Adding to rhoFluid
    Adding to kappaFluid
    Adding to UFluid
    Adding to phiFluid
    Adding to gFluid
    Adding to turbulence
Selecting turbulence model type RASModel
Selecting RAS turbulence model kOmegaSST
#0  Foam::error::printStack(Foam::Ostream&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#2  in "/lib/libc.so.6"
#3  Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
#4  void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#5  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator/<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
#6  Foam::compressible::RASModels::kOmegaSST::F2() const in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#7  Foam::compressible::RASModels::kOmegaSST::kOmegaSST(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#8  Foam::compressible::RASModel::adddictionaryConstructorToTable<Foam::compressible::RASModels::kOmegaSST>::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#9  Foam::compressible::RASModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#10  Foam::compressible::turbulenceModel::addturbulenceModelConstructorToTable<Foam::compressible::RASModel>::NewturbulenceModel(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so"
#11  Foam::compressible::turbulenceModel::New(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::basicThermo const&, Foam::word const&) in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/lib/libcompressibleTurbulenceModel.so"
#12
 in "/soft/OpenFOAM/OpenFOAM-2.1.x/platforms/linux64GccDPOpt/bin/chtMultiRegionSimpleFoam"
#13  __libc_start_main in "/lib/libc.so.6"
#14
Floating point exception
I am also attaching my BC for the fluid region. If I change the turbulenceProperties to laminar, everything works well. So, I guess, there is no problem in the domain and the mesh splitting in two regions.
Anyone with some ideas??
Regards,
Dhruv.
dhruv June 13, 2012 10:34
Solved
Hello All,
I solved this problem today. In the p file of the fluid, one of the boundary conditions needs to be modified to run it correctly.
Incorrect:
fluid_to_solid
type calculated;
value uniform 0;
This is not working. I replaced it by zeroGradient. Now the case works. Can anyone suggest why the other one does not work?
Thanks,
Dhruv.
