How can i run case in OpenFOam?
Old   June 22, 2012, 07:29
Default How can i run case in OpenFOam?
Premal Sheth
premal is on a distinguished road
Send a message via Yahoo to premal Send a message via Skype™ to premal
I had created .UNV mesh file in salome. Now how can i mesh file input in OpenFoam? and how can i run in the OpenFoam?
or
How can i run own any case in OpenFoam?
premal is offline   Reply With Quote
Old   June 23, 2012, 15:29
Retired Super Moderator
Bruno Santos
Greetings Premal,
Those are very generic questions, so I'll give you generic answers :
  1. Read the OpenFOAM User Guide to understand how to use OpenFOAM: http://www.openfoam.org/docs/user/
  2. Use the forum's "Search" menu -> "Advanced Search" in the yellow tool-bar above, to search for Salome in the OpenFOAM forum.
  3. Search with Google for:
    openfoam salome tutorial
Best regards,
Bruno
Old   June 24, 2012, 00:58
Premal Sheth
Thank you so much sir.....
i will try and if i will face any problem i will tell you.
Creating a case for uncoupledKinematicParcelFoam (OpenFOAM 1.6) andrewryan OpenFOAM 8 July 19, 2017 11:09
[Other] how run a DNS for ZPG turbulent boundary layer on a plate with OpenFOAM? dictatore_bozorg OpenFOAM Meshing & Mesh Conversion 3 October 9, 2015 05:08
Mapping of plot3d data to OpenFOAM case Fransje OpenFOAM 2 January 23, 2014 00:13
how to map results from steady state run to tranient case? phsieh2005 OpenFOAM Running, Solving & CFD 2 November 7, 2010 06:20
Executing Fluent case in OpenFOAM Viglen1956 OpenFOAM 0 June 7, 2010 06:47
