-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   conjugateHeatFoam for 4 different regions (http://www.cfd-online.com/Forums/openfoam/104325-conjugateheatfoam-4-different-regions.html)
lg88 July 6, 2012 21:04
1 Attachment(s)
Hello everybody,
I am going to use conjugateHeatFoam to simulate a conduction problem in a multi region case, thus including solid regions and fluid regions. I am using OF 1.6-ext.
There are 4 different regions, corresponding to different materials: A and C are solids, B and D is fluid (laminar). All the mesh is hexa,
Can solver conjugateHeatFoam realize my need?Do I need to modify the solver code?
thank you very much!
regards!
lg88
wyldckat July 9, 2012 17:29
Greetings lg88,
In response to the private message you sent me:
I'm not familiar with conjugateHeatFoam. But I think that chtMultiRegionFoam should be able to solve this issue, but again, I'm not very familiar with either one of these solvers.
Best regards,
Bruno
lg88 July 9, 2012 21:20
Thank you for your suggestion.But I am familiar with conjugateHeatFoam and my new solver is based on it.I hope use the solver to solve my problem.I found some information about the same problem I meet at [url]http://www.cfd-online.com/Forums/openfoam/89684-conjugateheatfoam-arbitrary-number-region.html.But there is not detailed construction.
Can anyone give me some idea?
Thank you very much!
lg88
su_junwei July 9, 2012 21:34
Originally Posted by lg88 (Post 370178)
Hello everybody,
regards!
lg88
conjugateHeatFoam can only deal with two different regions, three or more regions are not allowed. Use chtMultiRegionFoam instead please.
Regards, Junwei
lg88 July 11, 2012 00:25
hello
Thank you for your suggestion .I have checked in the forum and found that some people had applied conjugateHeatFoam to multi-regions successfully.And my new foam is developed based on the conjugateHeatFoam.
regards!
lg88
benk July 13, 2012 17:43
You need to edit the files attachPatches.H and detachPateches.H. You then have a main region and all other regions are treated as submeshes of the main region.
I've only done this for 3 regions, but 4 or more is definitely possible.
attachPatches.H (for 3 regions):
    const polyPatchList& patches = mesh.boundaryMesh();
    forAll (patches, patchI)
        if (isType<regionCouplePolyPatch>(patches[patchI]))
            const regionCouplePolyPatch& rcp =
                refCast<const regionCouplePolyPatch>(patches[patchI]);
            // Attach it here
            rcp.attach();
    // Force recalculation of weights
    mesh.surfaceInterpolation::movePoints();
    const polyPatchList& patches1 = separatorMesh.boundaryMesh();
    forAll (patches1, patchI)
        if (isType<regionCouplePolyPatch>(patches1[patchI]))
                refCast<const regionCouplePolyPatch>(patches1[patchI]);
            // Attach it here
            rcp.attach();
    separatorMesh.surfaceInterpolation::movePoints();
    const polyPatchList& patches2 = positiveMesh.boundaryMesh();
    forAll (patches2, patchI)
        if (isType<regionCouplePolyPatch>(patches2[patchI]))
                refCast<const regionCouplePolyPatch>(patches2[patchI]);
            // Attach it here
            rcp.attach();
    positiveMesh.surfaceInterpolation::movePoints();
detachPatches.H (for 3 regions):
            // Detach it here
            rcp.detach();
            // Detach it here
            rcp.detach();
            // Detach it here
            rcp.detach();
In the above, my submeshes are called "separatorMesh" and "positiveMesh".
Then in case/constant you have:
polyMesh/... (for the main mesh)
positive/polyMesh/... (for one submesh)
separator/polyMesh/... (for the other submesh)
In case/0 you have:
{fields for main mesh}
positive/{fields for positive mesh}
separator/{fields for separator mesh}
bryant_k July 14, 2012 10:53
Thank you for your detailed construction.I am also looking for the multi-region function of conjugateHeatFoam.
Regards!
kob
lg88 July 14, 2012 11:01
@benk
Thank you very much.I have modified my code as you said. Now it can work fluently and I am waiting for the results.Hoping it will work.
Regards!
lg88
ramon August 25, 2012 15:17
can anyone send me a simple tutorial of conjugateHeatFoam for multiregion (2fluid & 1solid) ?
thanks
mscheng October 19, 2013 22:35
Originally Posted by lg88 (Post 371442)
@benk
Regards!
lg88
Hi lg88,
In your case, can the boudaryField fully show in the solution file (such as T) using conjugateHeatFoam?
Thanks!
CHENG
