inlet1 depend on inlet2
Old   July 9, 2012, 06:39
Default inlet1 depend on inlet2
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all together,
is it possible to make one inlet dependend on the other inlet.
An example:
Total Pressure of Inlet1 and Inlet2 (101325 Pa)...
Outlet Pressure (101300 Pa) ...
Now I wanna have that the mass flow of inlet1 = 0.4 * inlet2
Can I manage that with groovy or sth. like that?
Thx.
Tobi
Tobi is offline   Reply With Quote
Old   July 9, 2012, 07:33
Roland
sylvester is on a distinguished road
Yes, groovyBC will do that for you.
From the average-t-junction example:
    outlet1
        type            groovyBC;
        valueExpression "0.5*(pInlet+pOutlet2)";
        variables       "pInlet{inlet}=sum(p*mag(Sf()))/sum(mag(Sf()));pOutlet2{outlet2}=p;";
        value           uniform 100010;
sylvester is online now   Reply With Quote
Old   July 9, 2012, 10:25
Tobi's Avatar
Tobias Holzmann
thanks for your replay.
Then my code should look like this:
inlet1
      type                pressureInletVelocity;
      value               $internalField;
inlet2
      type                groovyBC;
      valueExpression "vector(dependend,0,0)";
      variables          "dependend{inlet}=0.4*mag(U);";
Is that correct?
Old   July 9, 2012, 10:43
Roland
That's not going to work, for (at least) 3 reasons:
1. Your are referencing inlet instead of inlet1
2. You are using the vector U for the (scalar) component of Ux (use something link U.x instead, see manual)
3. U@inlet1 is a field not a single value, so it is best to calculated its average first (see the example I send before)
regards,
Sylvester
Old   July 9, 2012, 17:46
Tobi's Avatar
Tobias Holzmann
Oh thx.
Well I had no time to check it. It was my first guess
Tomorrow I ll have a look at the BC ...
Thx
Tobi
Old   July 10, 2012, 03:23
Tobi's Avatar
Tobias Holzmann
Hi Sylvester,
just two questions to you.
1. see manual - you mean the groovy manual? Or which one? Well I think its the only logical thing
2. Sf() - is it the flux through a surface like "Sf = Surface flux"?
Thanks in advanced
Tobi
Old   July 10, 2012, 03:35
Roland
Originally Posted by Tobi View Post
Hi Sylvester,
Yes, 'manual' is a bit confusing. Probably best is to look at the wiki, the examples provided with groovyBC, or the examples posted on this forum.
IIRC Sf() is the cell normal vector with the cell surface area as its magnitude.
Old   July 10, 2012, 04:06
Tobi's Avatar
Tobias Holzmann
Oh thanks. I get it now...
Now its working. Thats very nice. Hope that my simulation is more realistic as befor.
Tobi
Old   July 10, 2012, 04:16
Tobi's Avatar
Tobias Holzmann
Hi Sylvester,
just at least one question.
My BC looks like that:
    inlet
        type            zeroGradient;
        value           uniform (0 0 0);
    inlet2
        type            groovyBC;
        valueExpression "vector(dependendx,dependendy,dependendz)"
        variables       "dependendx=average(U.x);dependendy=average(U.y);dependendz=average(U.z);";
And both inlets are in the same directory.
Would you say that this BC I made is working correct? Well I have not much confidence.
anybody know how to define latent heat depend on variable temperature? alloveyou CFX 0 July 21, 2011 23:19
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
does physical property in fluent depend on P or just depend T only? gsyuan FLUENT 0 December 30, 2009 21:07
Morphing deforming surface mesh depend on some sensitivity field sponiar OpenFOAM Running, Solving & CFD 3 August 12, 2008 13:32
Time depend velocity inlet and outflow Seizopha FLUENT 2 January 14, 2005 21:01
