-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   help for a piece of code (http://www.cfd-online.com/Forums/openfoam/105584-help-piece-code.html)
bryant_k August 2, 2012 23:43
change values of a surfaceSalarField at boundary
Hello everyone
I want to change values of a surfaceSalarField sphi at boundary 'surface'.To other regions,the values keep default.So I write a piece of code :
sphi=sigma*(interpolate(U) &mesh.Sf())-fvc::snGrad(ha);
label patchI=mesh.boundaryMesh().findPatchID("surface");
forAll(sphi,patchI)
sphi[patchI]=sigma*(interpolate(U) &mesh.Sf());
But this is wrong.So can you tell me how to modify the above code?
regards!
bryant
wyldckat August 3, 2012 09:22
Hi Bryant, I got your message.
Look at the file "applications/utilities/postProcessing/wall/yPlusLES/yPlusLES.C" for answers ;)
Also look at "applications/utilities/postProcessing/wall/yPlusRAS/yPlusRAS.C" to see a more basic method of calculating yPlus. ;)
Best regards,
Bruno
bryant_k August 3, 2012 10:51
Hi Bruno
I have looked at the files which you suggested.I am confused with the code inside. I am not familiar with the LES or RAS.
Maybe I have not make my points clearly.Firstly the quantity 'sphi' is a surfaceScalarFiled.And then there are two different expressions for it.
sphi=sigma*(interpolate(U) &mesh.Sf())//this expression is just for the boundary 'surface'
sphi=sigma*(interpolate(U) &mesh.Sf())-fvc::snGrad(ha);//this expression is for other regions
So can you give me some suggestions in details?
Regards!
bryant
wyldckat August 3, 2012 14:03
If you abstract yourself from whatever LES and RAS are, you would see the details in bold and italic:
const fvPatchList& patches = mesh.boundary();
        const volScalarField nuLam(sgsModel->nu());
        forAll(patches, patchi)
            const fvPatch& currPatch = patches[patchi];
            if (isA<wallFvPatch>(currPatch))
                yPlus.boundaryField()[patchi] =
                    d[patchi]
                  *sqrt
                        nuEff.boundaryField()[patchi]
                      *mag(U.boundaryField()[patchi].snGrad())
                  /nuLam.boundaryField()[patchi];
                const scalarField& Yp = yPlus.boundaryField()[patchi];
                Info<< "Patch " << patchi
                    << " named " << currPatch.name()
                    << " y+ : min: " << gMin(Yp) << " max: " << gMax(Yp)
                    << " average: " << gAverage(Yp) << nl << endl;
It even detects if the patch is a wall...
This should translate to your case to be something like:
label patchI=mesh.boundaryMesh().findPatchID("surface"); forAll(sphi,patchI)
  sphi.boundaryField()[patchI] =
    sigma*(U.boundaryField()[patchi] & mesh.Sf());
Ah, wait, now I understand your issue with this... "yPlus" is a "volScalarField"...
OK, the closest I could find so far was "applications/solvers/multiphase/compressibleTwoPhaseEulerFoam/turbulenceModel/wallViscosity.H"...
I found it among the results from using this command:
find . -name "*.[CH]" | xargs grep -sl surfaceScalarField | sed 's=/[a-zA-Z0-9]*\..*==' | uniq | xargs grep -e "forAll(.*patc" -rsl
Basically it:
  1. Searches for files "*.[CH]";
  2. Then among those, the ones that mention "surfaceScalarFields";
  3. From those get the folders they're in;
  4. Make sure the list of folders is unique;
  5. The find in those folders for files that use "forAll" on patches.
Mmm... this is complicated... Anyone else wants to help?
wyldckat August 3, 2012 14:16
OK, I kept digging a bit deeper... in this file "applications/solvers/electromagnetics/magneticFoam/createFields.H", you'll find these pieces of code:
    surfaceScalarField murf
    surfaceScalarField Mrf
        const labelList& faces = mesh.faceZones()[magnetZonei];
        const scalar muri = magnets[i].mur();
        const scalar Mri = magnets[i].Mr().value();
        const vector& orientationi = magnets[i].orientation();
        const surfaceVectorField& Sf = mesh.Sf();
        forAll(faces, i)
            label facei = faces[i];
            murf[facei] = muri;
            Mrf[facei] = Mri*(orientationi & Sf[facei]);
Which would imply the need to do face-by-face calculations...
bryant_k August 5, 2012 03:09
Hi Bruno
Thank you for your help.
I have modified my code according the reference file.
forAll(sphi,i)
label zonei = mesh.faceZones().findZoneID("surface");
const labelList& faces = mesh.faceZones()[zoneonei];
    forAll(faces, i)
            sphi[facei] = sigma.value()*(U.boundaryField()[facei]& mesh.Sf[facei]);
I can complie it fluently.But it can not run correctly("segments fault").
I have a doubt at this line:
if I write
sphi[facei] = sigma*(U.boundaryField()[facei]& mesh.Sf[facei]);
it will failed in compiling.
Do you have any idea about this?
regards!
bryant
wyldckat August 5, 2012 08:08
Hi Bryant,
Something's very wrong here:
forAll(sphi,i)
  forAll(faces, i)
Do not use the same variable "i" for iterating in both loops!
And why is "zonei" being found inside the outer loop and not outside?
Best regards,
Bruno
