nutRoughWallFunction v1.6 - Values for Ks and Cs
Like Tree1Likes
  • 1 Post By herbert
Old   April 30, 2010, 04:49
Default nutRoughWallFunction v1.6 - Values for Ks and Cs
Heesei is on a distinguished road
Hello everyone
There are already some posts about nutRoughWallFunction, e.g. "nutRoughWallFunction and Surface Roughness Documented". But still I have a problem.
The following piece of code
type nutRoughWallFunction::Ks;
value uniform 0.001;
type nutRoughWallFunction::Cs;
value uniform 0.5;
seems to be correct. If I leave the values for Ks or Cs I get an error message. Nevertheless, I always get the same result no matter which values are chosen. I have also used different meshes but the result is always the same.
Does anyone know a solution to this problem? I think I am not the only one who is interested in this topic.
Thanks in advance.
Kind regards,
Irina
Heesei is offline   Reply With Quote
Old   April 30, 2010, 08:02
Default nutRoughWallFunction bug in 1.6 fixed in 1.6.x
gocarts's Avatar
Richard Smith
gocarts is on a distinguished road
nutRoughWallFunction in OpenFOAM 1.6 doesn't work correctly due to a bug. Try the latest 1.6.x from the git repository for the corrected version.
For more details on using nutRoughWallFunction try:
http://www.cfd-online.com/Forums/ope...ocumented.html
Hope this helps.
Symscape, Computational Fluid Dynamics for all
gocarts is offline   Reply With Quote
Old   June 17, 2010, 08:16
Exclamation Still a bug on nutRoughWallFunction?
maddalena's Avatar
maddalena
maddalena will become famous soon enough
Hello everybody,
I still have problems using nutRoughWallFunction with 1.6.x. More in detail, I have the same problems as posted above: whenever I change Ks (from extremely low to extremely high values), the results I get are always the same.
I am studying the flow around an airfoil at Re 1.5 millions and modeling turbulence with the KOmegaSST model. I defined the airfoil surface as:
  airfoil
    value uniform 0.00048;
Cs is not specified since I am using the default value of 0.5.
I tried different angles of attack and let the simulations converge till 1000 time steps. However, no changes on the aerodynamic coefficients while changing Ks. I tried different Ks, including 0 (smooth surface) and 1 meters, and also different turbulence models (kEpsilon). No changes. I am wandering if there is still some bug on the nutRoughWallFunction.
Any experience on that? Suggestions? Is there any incompatibility between schemes or parameter definition that let the simulation do not take into account the Ks?
Any help is appreciated.
Cheers,
mad
Last edited by maddalena; June 17, 2010 at 10:12. Reason: mispelled nutRoughWallFunction with nutWallFunction, observations apply without changes
maddalena is offline   Reply With Quote
Old   June 17, 2010, 09:53
Stefan Herbert
herbert is on a distinguished road
I've already worked with rough wall function in 1.6.x in my results are fine. Changing Ks had a big influence in my case. But I'm not sure if your BC is defined correctly, because you give no value for Ks but just for nut, which is in my opinion completely ignored. I used something like
airfoil
    type       nutRoughWallFunction;
    Ks          uniform 1e-5;
    Cs          uniform 0.5;
    value      uniform 0.0;
Regards,
Stefan
peppino likes this.
herbert is offline   Reply With Quote
Old   June 17, 2010, 10:06
maddalena's Avatar
maddalena
Hi Stefan and thanks for your answer.
I followed what posted by Irina above... However, using:
airfoil
    value uniform 0.0;
    Ks uniform 0.00048;
    Cs uniform 0.5;
did not changed my results. Also keeping Ks fixed and changing Cs did not produce any variation.
Maybe I installed the new OF 1.6.x version not properly. Do you know how can I switch on some debug to check whether the nutRoughWallFunction references are correct? In order to check if is a problem with my openFoam, I could also run a case that is working for sure for someone else... Maybe you have a really simple case I can test... May I try it?
Thank you.
mad
Old   June 17, 2010, 10:38
maddalena's Avatar
maddalena
Ok, switched on the debug flag (see Userguide!)
If I change the Ks, I can see that:
  • KsPlus changes --> OK!
  • Edash changes --> OK!
  • nutw = 0 in any case!
As explained here: http://www.cfd-online.com/Forums/ope...on-v1-6-a.html, this is the cause of the bug fixing of OF 1.6.x: nutw always inizialised to zero.
Thus, probably there is something wrong with my installation...
What do you think?
mad
Old   August 10, 2010, 07:33
Hi Maddalena
I installed OpenFOAM 1.7.x and used
lowerWall
Ks uniform 0.24;
Cs uniform 0.5;
value uniform 0.0;
as was suggested by Stefan. When changing Ks values my results changed as well. Finally, everything works fine. Maybe you should also install the latest version.
Cheers,
Irina
Old   August 10, 2010, 07:39
maddalena's Avatar
maddalena
Hi Irina and thanks for your interest. My problem was something different, see http://www.cfd-online.com/Forums/ope...tml#post264132. Everything worked when I changed mesh resolution.
Regards,
maddalena
Old   November 7, 2011, 17:19
aka
Getnet
aka is on a distinguished road
Regards,
maddalena
Does anyone of you tried Rough wall function in LES using OpenFoam?
Thanks
aka is offline   Reply With Quote
Old   July 31, 2012, 23:33
hfs
hfs is on a distinguished road
Thanks
Hello!
I am also interested in Rough wall function in LES ...
Have you got any ideas?
hfs is offline   Reply With Quote
Old   August 7, 2012, 11:08
David GISEN
David* is on a distinguished road
Hi hfs,
my only idea is to use fixedValue for nuSgs and e.g. nuTilda or every other LES parameter. Maybe it's possible to calibrate this value to behave like a normal roughness parameter. What do you think?
Cheers
David* is offline   Reply With Quote
Old   August 8, 2012, 07:19
hfs
Thanks for the idea ... am not sure ... will get back to you!
Thanks!
nutroughwallfunction
