-   OpenFOAM (http://www.cfd-online.com/Forums/openfoam/)
-   -   oldTime() outputting current time value: (http://www.cfd-online.com/Forums/openfoam/105809-oldtime-outputting-current-time-value.html)
gtg258f August 9, 2012 10:33
1 Attachment(s)
Dear all,
I have a solver with an outer time loop, and inner loop with sub-iterations. In order to check the convergence of the outer and inner iterations, I wanted to access my field values at the
- previous time step: p.oldTime()
- previous inner iteration: p.prevIter()
While prev.Iter() seems to work fine, I am encountering issues with oldTime() and was wondering if I was doing something wrong.
I am storing values with storePrevIter(), should I use something else for oldTime()?
Another option is that there may be a memory issue with oldTime:
when one adds print statements before modifying a field value, then oldTime() is stored properly whereas it is not without the print statement (which seems fishy)
Playing around with the problem, I wrote a very simple code (attached) with the following algorithm, and a set-up ready to run (though the example code really can run on any case)
DP=1
for( time )
    p.storePrevIter()
    //comment 1: print DP.oldTime()
    for( innerIteration<2 )
        DP.storePrevIter()
        DP+=DP
    //comment 2: print p.oldTime()
    p = DP
without any print statement, the values at the end of the first time steps are:
p[0] oldTime, prevIter, current = 4 1 4
DP[0] oldTime, prevIter, current = 4 2 4
with the print statements in comment 1 and 2, the values are properly stored and read as:
p[0] oldTime, prevIter, current = 1 1 4
DP[0] oldTime, prevIter, current = 1 2 4
Any help on that problem would be great,
Diane
