chtMultiRegionFoam - Courant number, deltaT, convergence criterion
Old   August 12, 2012, 21:09
Default chtMultiRegionFoam - Courant number, deltaT, convergence criterion
turbulencious is on a distinguished road
dear all,
I hope everybody is doing good
I came across something quite weird and I would like to share it with you in order to listen to the experience and suggestions of other people.
I simulate a laminar flow for a quite simple (though large) geometry, I use chtMultiRegionFoam of the latest version OF-2.1.1. It is a transient conjugate heat transfer problem.
Everything is good but I would like to speed up the whole simulation because I need to simulate a lot of hours and many times. I use adjustable timestep and maximum Co 5 (have tried 10 and 15) because higher values lead to divergence (weird, considering that Crank Nicholson should work for any timestep). Therefore I am limited to a very small timestep which will take me ages to get my results. So I have decided to change the convergence criteria in order to have lower computational time per time step (very desperate?). Anyway when I reduce the convergence criteria by one order of magnitude (1e-07 to 1e-06) this influences the deltaT, which drops from 4-5seconds to 0.2 seconds.
So the question is: What is the relation between the convergence criteria and the delta? Are there any ideas in order to speed up my simulations?
Thanks a lot in advance!
cordially,
Giorgos
turbulencious is offline   Reply With Quote
Old   August 13, 2012, 04:03
Olivier
olivierG is on a distinguished road
hello,
You can't get faster since chtMultiRegionFoam is a weakly coupled solver, and trying to solve with higer tolerance residual will not help you.
You may take a look at conjugateHeatFoam (1.6-ext).
regards,
olivier
olivierG is offline   Reply With Quote
Old   August 13, 2012, 05:13
thank you Olivier for your response!
what do you mean by take a look at conjugateHeatFoam. It is not available in the version that I am using. Can I still use it? And if yes, how can I use larrger time step?
thanks a lot
chtmultiregionfoam, converge, courant number increasing, openfoam 2.1.x
Convergence Centurion2011 FLUENT 48 June 14, 2022 23:29
Courant Number Problems wschosta OpenFOAM Running, Solving & CFD 5 February 28, 2020 03:45
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Courant Number in unsteady problems... vandadt FLUENT 0 November 8, 2009 16:12
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 07:36
