icofoam doubt
Old   September 20, 2012, 18:32
Default icofoam doubt
Mandeep
Rocky4 is on a distinguished road
Hello all,
I am new to openfoam and was just trying to understand icofoam code.
in the follwing portion of the code
set up the pressure equation
fvScalarMatrix pEqn
fvm::laplacian(rUA, p) == fvc::div(phi)
for setting pr eqn divergence of phi is used. if phi is scalar field(inner product of face velocity and surface area normal) then how can its divergence be defined ?
thanks in advance.
Rocky4 is offline   Reply With Quote
Old   September 26, 2012, 09:00
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
thanks in advance.
phi is actually a surfaceScalarField, which is a scalar (as you have noted) defined at each face of the particular cell. The divergence of this is then the summation of this surfaceScalar over the owner and neighbor faces. If you want to learn more about this, have a look at Dr. Jasak's Thesis here .
chegdan is offline   Reply With Quote
Old   October 5, 2012, 22:22
Mandeep
Thanks for ur kind response.
icoFoam VS pisoFoam-Laminar M3hdi OpenFOAM Running, Solving & CFD 17 May 21, 2022 00:55
Density in icoFoam Densidad en icoFoam manuel OpenFOAM Running, Solving & CFD 8 September 22, 2010 04:10
IcoFoam Not Installed and blockMesh command not found cesarbz OpenFOAM Installation 6 July 4, 2008 04:44
Kubuntu uses dash breaks All scripts in tutorials platopus OpenFOAM Bugs 8 April 15, 2008 07:52
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
