September 5, 2012, 21:07 |
Why simulation results showing "nan" values?
Sangeeta
Hello everyone,
I am running solidDisplacementFoam for 3D model. After simulation log file is showing "nan" values as given below: Iteration: 98 GAMG: Solving for T, Initial residual = 3.24013e-09, Final residual = 3.24013e-09, No Iterations 0 Min/Max/Ave T:-99.9999 99.9998 4.79039 GAMG: Solving for Dx, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for Dy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for Dz, Initial residual = nan, Final residual = nan, No Iterations 1000 Min/Max/Ave DEqnnan nan nan) (nan nan nan) (nan nan nan) ExecutionTime = 19286.7 s ClockTime = 19301 s Iteration: 99 GAMG: Solving for T, Initial residual = 3.24013e-09, Final residual = 3.24013e-09, No Iterations 0 Min/Max/Ave T:-99.9999 99.9998 4.79039 GAMG: Solving for Dx, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for Dy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for Dz, Initial residual = nan, Final residual = nan, No Iterations 1000 Min/Max/Ave DEqnnan nan nan) (nan nan nan) (nan nan nan) ExecutionTime = 19321.6 s ClockTime = 19336 s Iteration: 100 GAMG: Solving for T, Initial residual = 3.24013e-09, Final residual = 3.24013e-09, No Iterations 0 Min/Max/Ave T:-99.9999 99.9998 4.79039 GAMG: Solving for Dx, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for Dy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for Dz, Initial residual = nan, Final residual = nan, No Iterations 1000 Min/Max/Ave DEqnnan nan nan) (nan nan nan) (nan nan nan) Max sigmaEq = nan ExecutionTime = 19357.5 s ClockTime = 19372 s Does anyone have any idea why this problem is coming? Thanks, Sangeeta |
September 6, 2012, 14:45 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Sangeeta,
That basically means that the solver started to diverge when trying to solve Dx, Dy and Dz. You should look higher in the log file and look for where the simulation starts diverging. It can happen due to several reasons:
About keeping a log: taking as an example the tutorial "stressAnalysis/solidDisplacementFoam/plateHole", you can easily run that tutorial and clean that case by running the following commands:
Bruno
September 6, 2012, 22:06 |
#3 | |
Sangeeta
Hi Bruno, Thank you for the reply. I have generated a 3D mesh in snappyHexMesh and using this mesh for solving stress analysis by using solidDisplacementFoam solver. I have re-checked my boundary conditions, and fvSchemes (relaxation value etc.). I have used tighter tolerance and increased number of ncorrectors but still I am having same problem. I have gotten good simulation results for similar problem for 2D. Do you think that this problem is coming because of 3D geometry? Thanks in advance. Regards, Sangeeta |
September 8, 2012, 14:21 |
Bruno Santos
Rep Power: 128 |
Hi Sangeeta,
OK, there are two other points you can check/test:
Bruno
September 10, 2012, 12:37 |
#5 | |
Sangeeta
Thanks a lot for the reply. I hope this will help to solve my problem. Regards, Sangeeta |
Bubble Column Simulation: Different Turbulence Models different results | zobekenobe | CFX | 5 | January 28, 2013 09:02 |
Different results between 3 processors simulation and 7 processors simulation | mfmohdyasin | OpenFOAM Programming & Development | 1 | August 27, 2012 04:07 |
Simulation of a complex wing in solidworks flow simulation | niels1900 | FloEFD, FloWorks & FloTHERM | 6 | April 20, 2011 10:44 |
Gravity g's influence on Simulation Results | Colin | Main CFD Forum | 6 | November 2, 2003 14:13 |
graphical handling of simulation results | yf yap | Main CFD Forum | 3 | February 12, 2001 19:35 |
