OpenFOAM stress analysis results are showing 8-10% error with analytical solution.
Old   September 10, 2012, 12:52
Default OpenFOAM stress analysis results are showing 8-10% error with analytical solution.
Sangeeta
Sargam05 is on a distinguished road
Hello everyone,
I am running solidDisplacementFoam problem for thermal stress analysis. My solution is converged but not showing good agreement with analytical solution.
Simulation results shows 8-10% error with analytical solution. Does 8-10% error is fine for solid problems?
Has anybody an idea?
Regards,
Sangeeta
Sargam05 is offline   Reply With Quote
Old   September 10, 2012, 14:32
bigphil's Avatar
Philip Cardiff
bigphil will become famous soon enoughbigphil will become famous soon enough
Hi Sangeeta,
I presume you are referring to the "hollow cylinder with internal temperature" case as described by Timoshenko, Theory of Elasticity.
I tried this case and I found that the errors become very small (much much less than 1%) as you refine the mesh.
I have attached an graph showing a comparison between the results from a coarse and fine mesh.
To answer your question about "is 8-10% error ok?", in general for solid mechanics, it depends on the assumptions made in the analytical solutions (and in the numerical model). But for relatively straight-forward linear elastic and thermal elastic, the results should be very close to the analytical, especially as the mesh is refined.
Hope it helps,
Philip
bigphil is offline   Reply With Quote
Old   September 10, 2012, 15:06
Sangeeta
Originally Posted by bigphil View Post
Hi Sangeeta,
Hope it helps,
Philip
Hi Philip,
Thanks a lot for the reply. Actually here I am solving another problem of thermal stresses for OpenFOAM validation. This problem is given in Timoshenko (page no. 399). This is for a rectangular plate.
I am going to email this case to you.
Thanks,
Sangeeta
Old   May 5, 2017, 11:39
Default hollow cylinder with internal temperature
Guido Lupieri
glupieri is on a distinguished road
hello
I have tried to resolve the problem of the title, that is also a case of the tutorial,
by subjecting the 2D cylinder to the following boundary conditions:
for temperature T=100 in the hollow and T=0 at the outer patch,
for displacement D=0 tractionDisplacement (traction and pressure).
The results looks not as accurate as the ones of Dr. Cardiff/analytical case
that I have seen in this forum, even if I try to refine the grid.
Did somebody try the same tutorial case recently?
Thanks
Cheers
Guido
glupieri is offline   Reply With Quote
OpenFOAM - Validation of Results Ahmed OpenFOAM Running, Solving & CFD 10 May 13, 2018 18:28
comparison with analytical results (1D)and(3D) CFX Rogerio Fernandes Brito FLUENT 1 December 2, 2012 06:12
Cross-compiling OpenFOAM 1.7.0 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 3 September 8, 2010 06:25
Velocity spots in openFoam results Valle OpenFOAM Running, Solving & CFD 4 August 19, 2009 05:53
comparison with analytical results (1D)and(3D) CFX Rogerio Fernandes Brito CFX 2 October 28, 2008 20:26
