rotatingWallVelocity vs. SRF vs. MRF vs. AMI/GGI
Old   September 10, 2012, 19:14
Default rotatingWallVelocity vs. SRF vs. MRF vs. AMI/GGI
SV
Soheyl is on a distinguished road
This is a fundamental question that I need to think it through. I'm trying to model the flow inside the attached geometry. The mill (in white) rotates at a constant speed inside the casing (in red). The casing is a simple cylinder, and the whole system is filled with a single-phase liquid. Also, there is not protrusion on the outer surface of the rotating mill/shaft.
Can I simply model this using rotatingWallVelocity and say, simpleFoam? Would it automatically take care of the coriolis and centrifugal forces? (Notice that I will be modeling this in 3D). Also, considering the holes on the mill surface, would these methods work, or do I need a more advanced dynamic mesh method? Any thought/suggestion is highly appreciated.
Soheyl is offline   Reply With Quote
Old   September 11, 2012, 13:12
Kent Wardle
kwardle is on a distinguished road
Presumably the casing is stationary? Since you have only one moving domain and there are no baffles on your stationary cylinder (as near as I can tell from the image), there is no need for AMI/GGI. As you suggested, I think rotatingWallVelocity might barf because you have the holes in the rotating part--it is worth a try, but I think it wants to put just a tangential velocity on the surface which is not valid for the interior of your holes. SRF or MRF should have no problem at all. If there is not already a solver available, it is not too tricky to add in MRF capability to simpleFoam or whatever you will be using.
-KW
kwardle is offline   Reply With Quote
Old   September 12, 2012, 12:58
Attesz's Avatar
Attesz
Attesz is an unknown quantity at this point
I think rotatigWall will give bad results. I would use MRFSimpleFoam, but I would cut the domain into several domains very close to the plates. This would be the most accurate solution - if it is a steady phenomena, of course.
I am doing CFD Consulting Services.
Ich biete CFD Strömungssimulationen an.
Attesz is offline   Reply With Quote
Old   September 12, 2012, 14:19
Kent Wardle
If there are no baffles on the stationary part, then whether it is one rotating domain or multiple as Attesz has suggested should give the same results.
[ICEM] ICEM MRF Interface - Penetrating Elements survADe ANSYS Meshing & Geometry 9 February 4, 2015 02:26
Possible turbulence modelling bug in SRF solvers otm OpenFOAM Running, Solving & CFD 3 May 29, 2012 04:03
Should an empty MRF zone really induce this much cross-flow? sylvester OpenFOAM 5 November 18, 2010 03:48
MRF help please Atul T. Shinde FLUENT 1 December 19, 2002 01:20
Moving Mesh and MRF Romain FLUENT 1 May 16, 2002 03:45
