interFoam Meshing Error
Hello everyone,
I have made a very simple mesh of a 2-D tank in which I wish to simulate waves. But I'm getting this error when I do checkMesh: --> FOAM Warning : From function entry::getKeyword(keyType&, Istream&) in file db/dictionary/entry/entryIO.C at line 77 Reading /home/stripathi/OpenFOAM/stripathi-2.1.1/run/tutorials/multiphase/interFoam/laminar/wavetank/constant/polyMesh/boundary found on line 50 the punctuation token ')' expected either } or EOF --> FOAM FATAL IO ERROR: Expected a ')' or a '}' while reading PtrList, found on line 54 an error file: /home/stripathi/OpenFOAM/stripathi-2.1.1/run/tutorials/multiphase/interFoam/laminar/wavetank/constant/polyMesh/boundary at line 54. From function Istream::readEndList(const char*) in file db/IOstreams/IOstreams/Istream.C at line 159. FOAM exiting My blockMeshDict file looks like this: convertToMeters 1; vertices ( (0 0 0) (20 0 0) (20 0.1 0) (0 0.1 0) (0 0 2) (20 0 2) (20 0.1 2) (0 0.1 2) (0 0 3) (20 0 3) (20 0.1 3) (0 0.1 3) ); blocks ( hex (0 1 2 3 4 5 6 7) (20 1 3) simpleGrading (1 1 1) hex (4 5 6 7 8 9 10 11) (20 1 3) simpleGrading (1 1 1) ); edges ( ); boundary ( inlet { type patch; faces ( (0 4 7 3) (4 8 11 7) ); } outlet { type patch; faces ( (1 2 6 4) (4 6 10 9) ); } sides { type empty; faces ( (0 1 5 4) (4 5 9 8) (2 3 7 6) (6 7 11 10) ); } lower { type wall; faces ( (0 3 2 1) ); } atmosphere { type patch; faces ( (8 9 10 11) ); } ); mergePatchPairs ( ); Line 54 is where I write a parenthesis sign while assigning the faces to inlet patch. I don't understand what I'm doing wrong here. Please help. Thanks, Sagun |
