problem with using uniformFixedValue in OF 2.1.1
Hi dear Foamers
I wanna use timevarying BC in OF 2.1.1 My solver is icoFoam and I use ubuntu 12.04 0\U file is: Code:
inlet Reading field U Code:
I found my answer here:
http://www.cfd-online.com/Forums/ope...make-ramp.html I founded my fault . I should change to this for velocity: inlet { type uniformFixedValue uniformValue table ( ( 0 (0 0 0.0)) (100 (0 0 10.0)) ); } |
hi amin,
I think you should have to change your uniformFixedValue to timeVaryingUniformFixedValue. Then it will work. Thanks Regards Mallikarjuna |
Mallikarjuna,
TimeVaryingUniformFixedValue is an old BC that does not work in new versions of OpenFoam. |
