Inconsistent addressing between fine and coarse grids
Old   August 11, 2011, 15:37
Question Inconsistent addressing between fine and coarse grids
Radko Bankras
Radko is on a distinguished road
Hello all,
My OpenFOAM 2.0.0 simulation (rhoSimplecFoam) keeps crashing at random iteration steps with the following error:
[0] --> FOAM FATAL ERROR:
[0] Inconsistent addressing between fine and coarse grids
[0]
[0]     From function GAMGSolver::agglomerateMatrix(const label)
[0]     in file matrices/lduMatrix/solvers/GAMG/GAMGSolverAgglomerateMatrix.C at line 171.
[0]
FOAM parallel run exiting
Google and the forum search do not give any hints in a first search. Can someone tell me the meaning of the error and possibly a quick fix or workaround?
BR, Radko
Radko is offline   Reply With Quote
Old   September 16, 2012, 09:30
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I know its 2 years too late but I get the same error after switching my DDR3 memory frequency from 1333 MHz up to 1600 MHz. I tried 5 times the simulation and everytime I got the same error but it did not belong to a certain iteration time.
After switching back to 1333 MHz everything works fine again.
I had a look at my linux behavior and the frequency setted there:
Bios told me: 1600
Linux told me: 1333
Maybe there is something wrong with the linux settings.
If I know new thinks I ll tell it here.
Regard Tobi
Tobi is offline   Reply With Quote
Old   September 16, 2012, 10:38
Nima Samkhaniani
nimasam is on a distinguished road
you can use another solver such as GCC or ....
I know it is not solution it is to clear the question
nimasam is offline   Reply With Quote
Old   September 16, 2012, 11:09
Tobi's Avatar
Tobias Holzmann
I know that I can use a other solver but that`s the reason why the solver aborts every time (ram frequency).
inconsistent addressing
Create fine mesh that grows to coarse mesh (Urgent CZ FLUENT 1 January 3, 2009 10:36
HOW turbulene Grid (avoid too fine or too coarse)? Toulouser FLUENT 1 February 1, 2007 03:47
SIMPLE for fine grids Bharat Main CFD Forum 8 May 25, 2006 09:51
coarse grid to fine grid crashing Arnab Siemens 1 February 22, 2005 12:27
fine mesh ==> coarse mesh Mahbub Siemens 3 October 11, 2003 01:19
