September 19, 2012, 06:41 |
pimpleDyMFoam
Samuele Z
Rep Power: 18 |
Dear All,
I have a problem while I am trying to use the pimpleDyMFoam solver. As soon as I launch the simulation, I get this error: Code:
rduser@slnxepmi05:/OPENFOAM/cases/moving_door_def_flow/test/openingNoEnergy$ pimpleDyMFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-0bc225064152 Exec : pimpleDyMFoam Date : Sep 19 2012 Time : 12:34:52 Host : "slnxepmi05" PID : 23739 Case : /OPENFOAM/cases/moving_door_def_flow/test/openingNoEnergy nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: displacementSBRStress Selecting motion diffusion: quadratic Selecting motion diffusion: inverseDistance Reading field p Reading field U Reading/calculating face flux field phi --> FOAM FATAL IO ERROR: Unable to set reference cell for field p Please supply either pRefCell or pRefPoint file: /OPENFOAM/cases/moving_door_def_flow/test/openingNoEnergy/system/fvSolution::PIMPLE from line 69 to line 72. From function void Foam::setRefCell ( const volScalarField&, const volScalarField&, const dictionary&, label& scalar&, bool ) in file cfdTools/general/findRefCell/findRefCell.C at line 125. FOAM exiting Thanks a lot, Samuele |
September 19, 2012, 09:06 |
Rep Power: 18 |
In the fvSolution file, located in the system folder, write the options for pRefCell and pRefValue in the PIMPLE section, below the nNonOrthogonalCorrectors option:
PIMPLE { nOuterCorrectors .... nCorrectors ...... nNonOrthogonalCorrectors .... pRefCell 0; pRefValue 0; } |
September 19, 2012, 10:11 |
Samuele Z
Rep Power: 18 |
Oh, that's right.
Sorry for the question, Samuele |
Basic usage of pimpleDyMFoam | jferrari | OpenFOAM Pre-Processing | 7 | August 5, 2013 18:48 |
Help on segmentation fault with pimpleDyMFoam | ebah6 | OpenFOAM Running, Solving & CFD | 2 | July 5, 2013 07:27 |
Error with pimpleDyMFoam | samiam1000 | OpenFOAM | 2 | June 11, 2012 06:21 |
Running PimpleDyMFoam in parallel | paul b | OpenFOAM Running, Solving & CFD | 8 | April 20, 2011 05:21 |
pimpleDyMFoam stability problems | cnsidero | OpenFOAM Running, Solving & CFD | 3 | January 29, 2011 12:36 |
