What does uniform temperature rise mean for thermal stress analysis? |
September 19, 2012, 14:33 |
Sangeeta
Rep Power: 13 |
Hello everybody,
I am solving a thermal stress analysis problem in OpenFOAM. In my case, there is an initially undeformed cube subjected to a uniform temperature rise ΔT=T-Tr . As per my understanding, for this problem I do not need to solve energy equation. Does it means that I need to give some fix scalar value of the temperature in momentum equation for solving stresses due to temperature rise only? I appreciate if anyone could help me to understand the case. Thanks in advance. Best regards, Sangeeta |
September 21, 2012, 13:15 |
Philip Cardiff
Rep Power: 34 |
Hi Sangeeta,
Yes you are correct that since you know the temperature distribution you do not need to solve the energy equation. And then you would subtract the thermal stress term grad(3*K*alpha*deltaT) from the momentum equation. However, to save you changing the code you could just set fixedValue T boundary conditions and solve the energy equation using solidDisplacementFoam or elasticThermalSolidFoam, it probably wouldn't add much computation time and will give you the same temperature and displacement distributions. Philip |
September 22, 2012, 00:27 |
#3 | |
Sangeeta
Rep Power: 13 |
Hi Philip, Thank you for the reply. Yes, I am using elasticThermalSolidFoam for this case. Do you think that only fixing temperature in T boundary condition is fine to get good results. Because I can only fix temperature in boundary patches for e.g. TOP { type fixedValue; value uniform 100; } BOTTOM { type fixedValue; value uniform 100; } LEFT { type fixedValue; value uniform 100; } RIGHT { type fixedValue; value uniform 100; } FRONTANDBACK { type fixedValue; value uniform 100; } Does it means it rising uniform temperature in whole cube geometry? Kind regards, Sangeeta |
September 22, 2012, 11:34 |
Philip Cardiff
Rep Power: 34 |
Hi Sangeeta,
If you fix the boundary patch temperatures and then set the ddtScheme for T to be steadyState then the internal temperature field will be uniform 100. Philip |
September 22, 2012, 21:00 |
Sangeeta
Rep Power: 13 |
Hi Philip,
Thanks a lot for the information. I will try this. Kind regards, Sangeeta |
buoyantSimpleFoam for HVAC application | Mojtaba.a | OpenFOAM Running, Solving & CFD | 7 | November 16, 2017 15:49 |
Pressure instability with rhoSimpleFoam | daniel_mills | OpenFOAM Running, Solving & CFD | 44 | February 17, 2011 17:08 |
Time Dependent Temperature Dependent BC Analysis | RP | Main CFD Forum | 1 | March 28, 2008 01:22 |
stress analysis | rt | Main CFD Forum | 0 | June 7, 2007 05:01 |
Air temperature rise due to the compression of fan | Boris | FLUENT | 0 | January 27, 2003 21:11 |
