Home > Forums > OpenFOAM
Floating point exception when runnning elasticThermalSolidFoam
Old   September 27, 2012, 12:34
Default Floating point exception when runnning elasticThermalSolidFoam
Sangeeta
Sargam05 is on a distinguished road
Hello everybody,
I am solving a 2D square block case where temperature is changing only in y direction with zero displacement field at time=0. I am using pre calculated temperature values and fvScheme are not calculating for ddt scheme. My mesh is 100X100.
I have compiled elasticThermalSolidFoam solver for not calculation ddt scheme.
When I am running my case it is showing following problem:
Create time
Create mesh for time = 0
Reading field U
Patch bottomSurface Traction boundary field: U
Patch right Traction boundary field: U
max(detdd) = 2.75066e-32
min(detdd) = -1.11187e-48
average(detdd) = 2.32475e-33
min(detdd) = -6.84228e-49
average(detdd) = 2.33578e-33
nAddCells/nCells = 0.0198
Reading field T
Selecting rheology model linearElastic
Reading thermal properties
Selecting thermal model constant
surface method chosen for calculation of sigmaExp
Calculating displacement field
Time: 1
Solving for U using GAMG, residual = 1
Solving for U using GAMG, residual = 0.951875
Does anyone have any idea why this problem is coming and how to fix it?
Thanks in advace.
Best regards,
Sangeeta
Sargam05 is offline   Reply With Quote
Old   September 27, 2012, 16:30
Sangeeta
Hello everybody,
I have solved the problem which I have mentioned above. I have changed my BCs and now it is working
Best regards,
Sangeeta
Thread Tools
Trackbacks are On
No convergence; floating point exception all the time Tobi OpenFOAM 2 September 19, 2012 04:01
error EOF in blockMesh Ahmed Khattab OpenFOAM Meshing & Mesh Conversion 7 May 17, 2012 00:37
MPI Error - simpleFoam - Floating Point Exception scott OpenFOAM Running, Solving & CFD 3 April 13, 2012 16:34
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 18:29
Gmsh and samplesurface touf Open Source Meshers: Gmsh, Netgen, CGNS, ... 2 December 10, 2007 03:27
