calculating problem in a 3D case
Old   September 28, 2012, 02:22
Question calculating problem in a 3D case
sqing
Sunxing is on a distinguished road
I'm a new Foamer, I want to calculate a 3D case using rhoPimpleFoam solver, but there is something wrong that I can't deal ——
Starting time loop
Reading/calculating field UMean
Reading/calculating field pMean
Reading/calculating field UPrime2Mean
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Thanks!
Sunxing is offline   Reply With Quote
axisymmetric wedge case problem comedy_tigers88 OpenFOAM Running, Solving & CFD 0 June 16, 2012 04:45
Problem with axi-symmetric case using sonicFoam Madhura OpenFOAM 0 April 16, 2010 16:59
problem when I run the case Rui Siemens 1 February 1, 2007 06:25
case example for HVAC problem kevin FLUENT 0 April 3, 2004 12:09
Problem in calculating drag coefficient Sohail Ahmed FLUENT 2 March 18, 2004 00:40
