nakor |
September 29, 2012 16:31 |
decomposePar, 4 processors
I have a case which is running just fine with 1 processor, 2 processor (decomposition method : scotch) but when I try to run it with 4 processors, it is not working anymore.
I did tried two differents decompositions methods without any success.
The solver is starting, it is not diverging, but after some iterations, it stops with this error :
[2] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms in "/opt/openfoam211/platforms/linux64GccDPO/linux64GccDPOpt/lib/libOpenpt/lib/libOpenFOAM.so"
[1] #1 FOAM.so"
[2] #1 Foam::sigFpe::sigHandler(int)Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #2 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #4 Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[2] #8 in "/opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #7 Foam::fvMatrix<double>::solve(Foam::dictionary const&)Foam::fvMatrix<double>::solve() in "/home/caelinux/OpenFOAM/caelinux-2.1.1/platforms/linux64GccDPOpt/bin/mychtMultiRegionSimpleFoam"
[2] #9
in "/opt/openfoam21[2] in "/hom1e/caelinux/OpenFOAM/caelinux-2.1.1/platforms/linux64GccDPOpt/bin/mychtMultiRegionSimpleFoam"
[2] #10 __libc_start_main/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[1] #8 in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #11 Foam::fvMatrix<double>::solve()
[2] in "/home/caelinux/OpenFOAM/caelinux-2.1.1/platforms/linux64GccDPOpt/bin/mychtMultiRegionSimpleFoam"
[laptop:13776] *** Process received signal ***
[laptop:13776] Signal: Floating point exception (8)
[laptop:13776] Signal code: (-6)
[laptop:13776] Failing at address: 0x3e8000035d0
in "/home/caelinux/OpenFOAM/[romain-laptop:13776] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f37f270f4c0]
[laptop:13776] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x7f37f270f445]
[laptop:13776] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364c0) [0x7f37f270f4c0]
[laptop:13776] [ 3] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver13scalingFactorERNS_5FieldIdEERKS2_S5_S5_+0x77) [0x7f37f374b197]
[laptop:13776] [ 4] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver13scalingFactorERNS_5FieldIdEERKNS_9lduMatrixES3_RKNS_10FieldFieldIS1_dEERKNS_8UPtrListIKNS_17lduInterfaceFieldEEERKS2_h+0xa6) [0x7f37f374b426]
[romain-laptop:13776] [ 5] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver6VcycleERKNS_7PtrListINS_9lduMatrix8smootherEEERNS_5FieldIdEERKS8_S9_S9_S9_RNS1_IS8_EESD_h+0xfa0) [0x7f37f374dc90]
[laptop:13776] [ 6] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZNK4Foam10GAMGSolver5solveERNS_5FieldIdEERKS2_h+0x4c3) [0x7f37f374ec23]
[laptop:13776] [ 7] /opt/openfoam211/platforms/linux64GccDPOpt/lib/libfiniteVolume.so(_ZN4Foam8fvMatrixIdE5solveERKNS_10dictionaryE+0x137) [0x7f37f5875307]
[laptop:13776] [ 8] mychtMultiRegionSimpleFoam(_ZN4Foam8fvMatrixIdE5solveEv+0xc0) [0x432530]
[laptop:13776] [ 9] mychtMultiRegionSimpleFoam() [0x422498]
[laptop:13776] [10] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f37f26fa76d]
[laptop:13776] [11] mychtMultiRegionSimpleFoam() [0x424c8d]
[laptop:13776] *** End of error message ***
caeli--------------------------------------------------------------------------
mpirun noticed that process rank 2 with PID 13776 on node romain-laptop exited on signal 8 (Floating point exception).
Final Time 22:23:06
Simulation Time: 29 secondes
Simulation Time: 0 minutes
Any ideas why this could happen ? I am using OpenFoam 211.
Thanks for your help.
