unable to get parabolic velocity profile with pimplefoam
2 Attachment(s)
Hi foamers!
In my last thread, I modified a pimplefoam tutorial case into a laminar, 2d channel flow. The boundary conditions I applied could be summarized as: inlet: fixedvalue velocity / zerogradient pressure outlet: zerogradient velocity / fixed value pressure(=0 pa) wall: fixedvalue velocity (0 0 0) / zerogradient pressure frontandback: empty From theory I knew for a fully developed channel flow, velocity profile on outlet should be parabolic with max velocity equals 1.5 times average velocity which should be the inlet velocity here, and this profile should have nothing to do with viscosity and density. However, even I simulate very long time(3000 seconds), I can only get the following velocity profile: Attachment 16070 Attachment 16071 Any ideas about this? Also I want to know, how could I debug the pimplefoam using gdb, for example, view how the pressure field changing every time step. Is it necessary to modify the source code to add some print out code? (I have already compiled of with a debug flag) thanks in advance |
1- whats the value of your inlet velocity? is it a laminar at all?
2-what the ration of length to width? as you know when you apply a uniform inlet, there is an entrance length, after that flow would be developed |
1 Attachment(s)
I also noticed may be the problem is entrance length. If I raise the dynamic viscosity 100 times, to 1e-3, I could now view the "normal" parabolic velocity profile. Attachment 16073 It seems that the lower viscosity, the longer entrance length will be. However I read my textbook which says entrance length is usually about 116*D for laminar flow, where D is the channel diameter...seems no relation with viscosity... |
Would you kindly comment on my second question, about how to debug and view data with gdb? |
