August 28, 2010, 09:52 |
what is nutilda?
Dear Foamers,
What is nutilda? i found it in 0 folder of les and kepsilon of pisoFoam tutorial (also other solvers). what should be its value in boundaries: wall, inlet, outlet ? Best, |
August 28, 2010, 20:22 |
Chris Sideroff
Rep Power: 22 |
nuTilda is for the Spalart-Allmaras turbulence model (the value solved for that determines the turbulent vicosity). See: http://www.cfd-online.com/Wiki/Spalart-Allmaras_model
The nuTilda file will ignored unless you have enabled the SA turbulence model. |
August 29, 2010, 10:24 |
#3 | |
do you mean it is not important when using k-e, LES & ... turbulence methods? it is available in o folder of these tutorials. also tell me about "nut" and "nusgs" if possible. Regards, Maysam |
August 28, 2012, 09:38 |
Canakkale Dardanelspor
Rep Power: 13 |
nuSgs is the choice of wall function for the incompressible LES. Simply, kinematic viscosity.
Check it out? http://www.openfoam.org/docs/user/turbulence.php |
October 11, 2012, 11:26 |
Sagun Tripathi
Rep Power: 13 |
Hello everyone,
In continuation with the topic, how does one determine the values of kqRWallFunction and epsilonWallFunction? Thanks, Sagun |
nut and nuTilda | phile | OpenFOAM Running, Solving & CFD | 32 | June 13, 2020 08:53 |
SimpleFoam nutilda an R | linnemann | OpenFOAM Running, Solving & CFD | 13 | October 9, 2014 08:14 |
pimpleDyMFoam diverging | gfilip | OpenFOAM Running, Solving & CFD | 22 | December 30, 2013 17:04 |
RasInterFoam STRANGE RESULTS AT BOUNDARY | kumar2 | OpenFOAM Running, Solving & CFD | 8 | March 24, 2008 18:38 |
What does the variables R and nuTilda represent in the icofoam | ztdep | OpenFOAM Running, Solving & CFD | 2 | August 18, 2005 22:21 |
