how to define the motionSolver
Old   October 9, 2012, 19:40
Default how to define the motionSolver
conceptone is on a distinguished road
Hi everyone, right now I am running the sprayEnginefoam. In the engineGeometry input file, I select the fvMotionSolver for engineMesh for dynamic meshing,but I got the error message below. Is there anyone knowing how to define the initial value for motionSolver in the input file? Thanks.
--> FOAM FATAL IO ERROR:
keyword motionSolver is undefined in dictionary "/usr/people4/liao23/sprayEngine_runcases/biggermesh2/constant/engineGeometry"
file: /usr/people4/liao23/sprayEngine_runcases/biggermesh2/constant/engineGeometry from line 18 to line 29.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 400.
FOAM exiting
conceptone is offline   Reply With Quote
Old   October 10, 2012, 03:10
Peter_600 is on a distinguished road
Just plug in motionSolver in ur dictionary file. Than re-run yyour case. It will complain anyways , but also gives you a list with available motionSolvers. Than choose just one of them. OR check the source code itself.
Peter_600 is offline   Reply With Quote
Old   October 10, 2012, 21:15
Thanks for replying, but I tried the first way by:
engineMesh fvMotionSolver;
motionSolver dummy;
in engineGeometry file
and it returns:
cannot open file
file: /usr/people4/liao23/sprayEngine_runcases/biggermesh_0rpm/constant/dynamicMeshDict at line 0.
From function regIOobject::readStream()
in file db/regIOobject/regIOobjectRead.C at line 87.
I also read the code in fvMotionSolverEngineMesh.C but didn't figure out..I am not familiar with C++....
Old   October 11, 2012, 03:11
Go ahead an create your dynamicMeshDict.
Are u using 1.6-ext? If yes and u are want to use engineMesh, u can choose between the following classes, which are derived from engineMesh:
layeredEngineMesh
staticEngineMesh
tetDecompositionEngineMesh
try one of these! instead of fvMotionSolver
Cheers Peter
Old   October 11, 2012, 13:44
acutually I am using 2.1 version and fvMotionSolverEngineMesh in 1.6 also needs to input the fvMotionSolver. But still thanks!
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 09:23
Missing math.h header Travis FLUENT 4 January 15, 2009 11:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 10:19
