Home > Forums > OpenFOAM
Problem with mapFieldsDict
Old   October 30, 2012, 05:56
Default Problem with mapFieldsDict
Samuele Z
samiam1000 is on a distinguished road
Dear All,
I have a problem with mapFieldsDict.
This is my dictionary:
|  \\    /   O peration     | Version:  1.7.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      mapFieldsDict;
patchMap
    wall-part_2-solid wall-part_2-solid
    wall_roof_channel wall_roof_channel
    back back
    floor floor
    hc_ii hc_ii
    inlet_main inlet_main
    intake intake
    intake_ii intake_ii
    lato_interno_1 lato_interno_1
    lato_interno_2 lato_interno_2
    roof roof
    symmetry_ext_1 symmetry_ext_1
    symmetry_ext_2 symmetry_ext_2
    wall_infinite wall_infinite
	door door
cuttingPatches
The problem is that in this way when I write
 mapFields -sourceTime 10000 ../../steady/steady2D/
I get this:
rduser@slnxepmi05:/OPENFOAM/cases/moving_door_def_flow/test/opening/disappearing2D$ mapFields -sourceTime 10000 ../../steady/steady2D/
|  \\    /   O peration     | Version:  2.1.0                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.0-0bc225064152
Exec   : mapFields -sourceTime 10000 ../../steady/steady2D/
Date   : Oct 30 2012
Time   : 10:57:44
Host   : "slnxepmi05"
PID    : 22716
Case   : /OPENFOAM/cases/moving_door_def_flow/test/opening/disappearing2D
nProcs : 1
allowSystemOperations : Disallowing user-supplied system call operations
Source: "../../steady/steady2D" ""
Target: "/OPENFOAM/cases/moving_door_def_flow/test/opening" "disappearing2D"
Create databases as time
Source time: 10000
Target time: 0
Create meshes
Source mesh size: 119473	Target mesh size: 119473
Mapping fields for time 10000
End
and nothing happens, while if I write
 mapFields -consistent -sourceTime 10000 ../../steady/steady2D/
without the mapFieldsDict, it works.
The problem is that I need the 1st way, since I'd like to remove the patch ``door''.
What's wrong with my dictionary?
Thanks a lot,
Samuele
Last edited by samiam1000; October 30, 2012 at 06:43. Reason: I forgot to edit the command
samiam1000 is offline   Reply With Quote
Old   November 14, 2013, 08:26
openfoammaofnepo is on a distinguished road
Dear samiam1000,
I had the same problem about the mapping the results between different geometries. Actually most of the parts are the same but I just changed one of the BC. When I did the mapFields, it gave me nothing in my target folder. Could you please tell me how did you solve this problem in your case? Thank you.
Originally Posted by samiam1000 View Post
Dear All,
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
patchMap
    back back
    floor floor
    hc_ii hc_ii
    intake intake
    intake_ii intake_ii
    roof roof
	door door
cuttingPatches
I get this:
Date   : Oct 30 2012
Time   : 10:57:44
Host   : "slnxepmi05"
PID    : 22716
nProcs : 1
Source time: 10000
Target time: 0
Create meshes
End
Thanks a lot,
Samuele
openfoammaofnepo is offline   Reply With Quote
Thread Tools
Trackbacks are On
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 04:43
Gambit - meshing over airfoil wrapping (?) problem JFDC FLUENT 1 July 11, 2011 05:59
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 06:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 19:13
Is this problem well posed? Thomas P. Abraham Main CFD Forum 5 September 8, 1999 14:52
