mapFields problem
Hi everyone,
I am having problems mapping fields from a coarser mesh to a finer mesh using mapFields in a parallel simulation. My source (low res) case was run in parallel (the domain is decomposed into 24 subdomains) and the geometry and boundary conditions are consistent with my target case. So initially I decomposed my target (high res) case first then performed mapFields using the following tags: - consistent - parallelSource - parallelTarget However this didn't work. I then reconstructed my source case and then used this single time directory to map to the decomposed target case using the following tags: - consistent - parallelTarget But this still didn't work. I then just tried to mapFields from the single reconstructed time directory to a single target before decomposing the domain using the following tags: -consistent and it still didn't work. For every method I tried the result was the same: it never seemed to even start. You can see this in the shell output below: | \\ / O peration | Version: 2.1.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.1.0-bd7367f93311 Exec : mapFields hming1@msgln6.its.monash.edu.au:SCRATCH/NEW-SCRATCH/1100k_3 -case . -consistent Date : Nov 08 2012 Time : 00:41:55 Host : "gn139.its.monash.edu.au" PID : 28321 Case : /scr-nfs/stefano-2012/hming1/3900k_1 nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Source: "hming1@msgln6.its.monash.edu.au:SCRATCH/NEW-SCRATCH" "1100k_3" Target: "/scr-nfs/stefano-2012/hming1" "3900k_1" Create databases as time Does anyone have any idea how to fix this? Thanks |
You need to create initial data files in your target directory. The target directory and the source directory need to be at the same time.
