Find Center of Pressure?
Like Tree1Likes
Old   December 22, 2012, 08:45
Doug68 is on a distinguished road
Carrying on with the brute force and ignorance approach...
Using the method shown further up the thread I set up to create results on 11 CoR's 100mm apart on a straight line on the XZ plane, this covered the 1m where I guessed the CoP was somewhere within.
Plotting out the results as shown below where the line crosses the X axis torque is 0, therefore that's the CoP in the X direction.
Doug68 is offline   Reply With Quote
Old   December 22, 2012, 16:27
GPan1 is on a distinguished road
I'm 99% sure the moments are due to the vortexes shed by the wheel, which oscillate and why I don't get 100% convergence. Eliminating the wheel moments / atleast in x and z axes (which seems reasonable) and having y as non-zero, I can get two equations in the form of x and z, and use simple simultaneous equations to solve, however it's dependant on the CofR I pick.
That said your latest method makes the most sense of all methods I've tried, because centre of pressure will be where the moments are zero, so plotting My/Mx/Mz from several CofR's should give you the location. Genius!
Always looking for something more complex than it should be
Edit - had a think, but that's till dependant on the CofR because that will give you the position of zero torque at 0 height, which means CP would occur at more than one position, and you'd need to do a lot of iterative solutions before finding it?
GPan1 is offline   Reply With Quote
Old   December 26, 2012, 19:46
Yeah, you are right my last effort will give the zero torque point at the elevation stated.
more thought required
Old   January 2, 2013, 03:11
So now I believe that finding the CoP using the data on forces.dat on its own is not possible.
Regardless of the number of files produced for different CoR's.
I think the most that can be proven is that there will be a line upon which the CoP lies.
I'm pretty certain the method that needs to be followed is as julien.decharentenay describes in post 2 of this thread.
Old   February 12, 2013, 09:45
stephane sanchi
openfoam_user is on a distinguished road
following the link below you will find a paper called "Forces and moments in CFD analysis" and written by Zdeněk Říha.
http://ebookbrowse.com/riha-forces-a...pdf-d253480950
Comments about this paper are welcome.
Regards,
Stephane.
FJSJ likes this.
openfoam_user is offline   Reply With Quote
Pressure Inlet VS velocity Inlet difference Mohsin FLUENT 9 January 4, 2021 10:34
Pressure BC for combustion chamber Giuki FLUENT 1 July 19, 2011 11:35
center of pressure Filippo FLUENT 2 March 29, 2007 02:48
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 22:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
