Boundary conditions for 2D Navie-Stockes simulation
Like Tree2Likes
  • 2 Post By olivierG
Old   March 7, 2011, 09:46
Default Boundary conditions for 2D Navie-Stockes simulation
L1011 is on a distinguished road
Hi Foamers!
In the past days I tried to set the case of a simple 2D-incompressible simulation of an airfoil using a O-mesh with the influence of both viscosity and turbulence (SST model) using pisoFoam.
As shown on the figure below, the topology of my case is made of:
  1. a body
  2. an internal field
  3. an inlet/outlet
on which I have to set boundary conditions; basically a freestream velocity vector and an adiabatic/no-splip boundary at wall.
Based on searches in the forum I have 3 questions for you:
A) In the 0/ folder, why do we need to set boundary conditions for all the working variables on all the boundaries? (For example, at wall, couldn't we just set the velocity to 0 instead of adding also a BC for the pressure ?)
B) How can I set non-reflecting boundary conditions for the farfield?
C) Based on my experience, I tried the boundary conditions mentioned hereafter. The computation ran properly but I do not get the right cp distribution nor aerodynamic coefficient values. Did I make a major mistake?
|  \\    /   O peration     | Version:  1.4.1                                 |
|   \\  /    A nd           | Web:      http://www.openfoam.org               |
// Field Dictionary
FoamFile
    version         2.0;
    format          ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class           volVectorField;
    object          U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (25 0 0);
boundaryField
    inlet-outlet
        type            fixedValue;
        value           uniform (25 0 0);
    body
        type            fixedValue;
    value           uniform (0 0 0)
    defaultFaces
        type            empty;
// Field Dictionary
FoamFile
    version         2.0;
    format          ascii;
    root            "";
    case            "";
    instance        "";
    local           "";
    class           volScalarField;
    object          p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 82714;
boundaryField
    inlet-outlet
        type            zeroGradient;
    body
        type            zeroGradient;
    defaultFaces
        type            empty;
|  \\    /   O peration     | Version:  1.7.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      k;
internalField   uniform 0.001;
boundaryField
    inlet-outlet
        type            fixedValue;
        value           uniform 0.001;
    body
        type            zeroGradient;
    defaultFaces
        type            empty;
|  \\    /   O peration     | Version:  1.7.x                                 |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      mut;
dimensions      [1 -1 -1 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet-outlet
        type            calculated;
        value           uniform 0;
    body
        type            mutLowReWallFunction;
        Cmu             0.09;
        kappa           0.41;
        E               9.8;
        value           uniform 0;
    defaultFaces
        type            empty;
FoamFile
    version     2.0;
    format      ascii;
    class       volSymmTensorField;
    object      R;
internalField   uniform (0 0 0 0 0 0);
boundaryField
    inlet-outlet
        type            kqRWallFunction;
        value           uniform ( 0 0 0 0 0 0 );
    body
   defaultFaces
        type            empty;
Thank you very much and have a good week!
L1011
File Type: png Capture d’écran 2011-03-07 à 08.58.17.png (33.3 KB, 61 views)
L1011 is offline   Reply With Quote
Old   March 9, 2011, 05:33
Olivier
olivierG is on a distinguished road
A) There is not "default condition" in OF, so you must set boundary condition for all variables.
B)
1) For airfoil simulation, first rule is to set your far field domain to 30 - 50 chord lenght. From your picture, you are at 2 only, and you will have big reflexion and distorsion in the u and p field.
2) Your boundary conditions are not optimal. Try:
For U, at inlet-outlet, try the inletOutlet condition
For p, at inlet-outlet, try outletInlet
For k, at inlet-outlet: inletOutlet, and for your wall: fixedValue if y+<1 or kqRWallFunction if y+>30
For omega (if kw SST), the same, i.e inletOutlet and omegaWallFunction at wall.
For mut, seem ok if you use a low Re turbulence model (kw SST is not a low Re model), or mutWallFunction
For R, at inlet-outlet you should try inletOutlet too.
FvScheme: don't forget to use Gauss upwind for div scheme with k/epsilon/omega at first.
FvSolution: set tolerance for omega/k/epsion to a low value , i.e 1e-15, and play with relTol (start at 0.1 to ...1e-6)
Hope this help
olivier
mm.abdollahzadeh and mechy like this.
olivierG is offline   Reply With Quote
Old   March 9, 2011, 22:32
Hi Olivier,
Thank you for your hints, I'll try to make a comparative study with the results already get.
L1011
Old   December 11, 2012, 10:26
VS
VSass is on a distinguished road
OivierG,
your post was very helpful to me also,but i want to ask if there is any specific reason or criteria for using outletInlet for p and not inletOutlet?
The same question occurs for velocity.How do we choose one or the other?
VSass is offline   Reply With Quote
Old   December 11, 2012, 12:08
Olivier
hello,
outletInlet use zeroGradient in case of inflow, and fixedValue for outflow,
inletOutlet use fixedValue for inflow, and zeroGradient for outflow,
so you see that you will use inletOutlet for U at both inlet & outlet, and outletInlet for p (inlet & outlet).
You may try the opposite (i.e use a fixed outflow velocity), but this is realy not a good idea.
regards,
olivier
Old   December 13, 2012, 08:17
Default rhosimplecfoam
sh.d is on a distinguished road
Hi
I want simulate a supercritical airfoil by using rhosimplecfoam.mach number is 0.5.but, I do not know what boundary conditions should I use?
pleas help me?
sh.d is offline   Reply With Quote
Impinging Jet Boundary Conditions Anindya Main CFD Forum 25 February 27, 2016 12:58
CFX does not continue Shafiul CFX 10 February 17, 2011 07:57
Boundary conditions for pipework simulation metro OpenFOAM Running, Solving & CFD 0 August 12, 2010 03:13
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Need help about boundary conditions for a francis runner flow simulation Rodrigo Escobar Moragas Main CFD Forum 1 October 26, 1998 08:20
