Alternatives for InterFoam - High Viscosity Ratio Problem |
November 13, 2012, 14:30 |
Saba Saeb
Rep Power: 15 |
Hi all,
The problem of InterFoam solver when it comes to two different materials with high viscosity ratio has been already discussed in another topic and is confirmed according to the following (bug) report : http://www.openfoam.org/mantisbt/view.php?id=156 Now, is there any other solver that can be used instead of InterFoam which doesn't make any problem in this special case? Your help and suggestions would be much appreciated. Cheers, Saba |
November 13, 2012, 15:05 |
Kyle Mooney
Rep Power: 17 |
Have you tried to implement additional PISO iterations or switch to a PIMPLE mode as the mantis report recommends?
November 13, 2012, 15:12 |
Saba Saeb
Rep Power: 15 |
Hi Kyle,
I tried both approaches suggested in the report, but as it is mentioned, it takes too much time and even worse, the problem doesn't converge at all when the viscosity ratio gets higher, like 10e5! Cheers, Saba |
November 13, 2012, 16:57 |
Kent Wardle
Rep Power: 21 |
Not sure about this, but if you are looking for options you might try multiphaseEulerFoam instead. In that case each phase has it's own momentum equation rather than a shared velocity field as in interFoam. Not sure if this will help or hurt the problem, but it is another thing to try. I would be curious to hear of your results.
-Kent |
InterFoam viscosity problem / possible bug | pbryant | OpenFOAM Running, Solving & CFD | 24 | March 30, 2020 04:25 |
Trans. SST Intermittency Factor and Viscosity Ratio | eishinsnsayshin | FLUENT | 3 | May 23, 2012 03:02 |
turbulent viscosity limited to viscosity ratio of 1.000000e+05 | syler3321 | FLUENT | 4 | March 16, 2012 16:00 |
Problem on high density ratio in Level Set method | Kai Yan | Main CFD Forum | 10 | December 25, 2007 06:12 |
Turbulent viscosity limited to viscosity ratio... | Cyril | FLUENT | 8 | February 7, 2006 20:34 |
